    Lower Poly?
    extensions
    3 Posts 1 Posters 1.0k Views 1 Watching
      twharvey
      I've only been playing with Sub-Smooth for a couple of days. I'm using it to model for GE, so I want as low a face/edge count as possible. I can make up for some of the detail of smoothing with the photo textures applied later. I have a couple of questions:
      1. Is there a way to restrict the strength of the Subsmooth action in the first place, i.e., less smoothing and fewer faces in the resulting component?
      2. If that doesn't work, is there a way to simplify the component after it's done with the Subsmooth operation?
      Thanks,
      Tom
      Tom
        twharvey
        Thanks, James
        Tom
        Tom
          twharvey
          James,
          OK, I did some with 1 iteration. That results in a much lower poly count.
          Thanks again,
          Tom
          Tom
