    XP 64 on an Intel Mac?
    45 Posts 7 Posters 2.6k Views 7 Watching
    • StinkieS Offline
      Stinkie
      Really? Which ones?
      • StinkieS Offline
        Stinkie
        I must correct myself: Home Basic 64 supports 8 gb, Home Premium supports 16 gb, and Ultimate, Business and Enterprise support + 128 gb.
        So Home Premium 64 might be enough for me.
          remus
          But how will you ever be able to do 50,000x50,000 renders with only 16gb of ram? You wont stand a chance stinkie, upfrade, you know you want to 😄
          • StinkieS Offline
            Stinkie
            Well, Remus, I went shopping, and finally decided upon getting Ultimate, so ... 💚
            Anyway, I think 8 gb will last me a while.
            • StinkieS Offline
              Stinkie
              Mornin' SU folk!
              I tried to install Vista Ultimate 64 bit on my Mac Pro last night, but: no dice. The 32 bit version (which I tried also) installed just fine, but the 64 one ... This is what happened: I started up the Bootcamp Assistant and made me a nice Windows partition. When that was done, the computer rebooted to start the actual installation process (the Vista cd-rom was already in the drive, of course). When it did, it showed me a nice black sceen, with nice white letters on it:
              Select CD-ROM Boot Type
              Now, it seems obvious I have to make a choice at this time: 1 or 2. Apart from the fact I have no clue what either of these choices are, I cannot type squat. The computer doesn't respond to the keyboard. 👊
              Any thoughts? Aphorisms? Poems?
                remus
                Ive got to go and et ready for my first exam, might be able to give you a hand when i get back though. A good starting point would be to read this: http://forums.macrumors.com/showthread.php?t=468385
                • StinkieS Offline
                  Stinkie
                  Thanks for the link. I got all day at the office to dredge trough Mac forums to find a solution for this, erm, interesting problem. 😉
                  Kind of reminds me of the days I enjoyed myself with installing obscure Linux distributions on an old Pentium 3. 💚
                  Ah, the panic, the stress! 😄
                    remus
                    Lol, have you downloaded the latest version of boot camp? (if you can download it, ive never had to try myself)
                    • StinkieS Offline
                      Stinkie
                      I used the version that came with my Leopard install disc. I did get this, though: http://www.apple.com/downloads/macosx/apple/application_updates/bootcampupdate21forwindowsvista64.html
                      Strangely, that's an exe file.
                        remus
                        Do .exe not run on macs then? I havent used a mac for a while and i cant remeber what extension their executables have...
                        • StinkieS Offline
                          Stinkie
                          AFAIK, they don't run, no. Now, I'm not worried. A quick Google search taught there's plenty of people out there who experienced the same issue. There's bound to be a solution.
                          • StinkieS Offline
                            Stinkie
                            Some poking around turned up this:
                            "1. Insert Windows Install disc into DVD drive
                            2. Using the build mode of imburn, go to the advanced tab, then bootable disc and then select your DVD drive in the extract boot image drop down list. Go ahead and extract the boot image and store it somewhere on your hard drive
                            3. Go to the information tab and add your DVD drive as the source file
                            4. Options tab, check that file system is ISO9660 + IDF and UDF revision is 1.02 (should be anyway by default)
                            5. Go to Advanced tab, sub tab Restrictions and further sub tab ISO9660: Set Folder / File length to Level X and tick the four check boxes at the bottom (allow more than 8 directory levels, Allow more than 255 characters in path, Allow files without Extensions, Don’t Add ‘;1’ Version number to Files. (Note it’s this bit that actually solves the problem the rest is effectively just duplicating the existing disc)
                            6. Move to the bootable disc tab: Click the tick box to make the image bootable, emulation type to “none (custom)” and the browse and select the boot image you previously extracted from the windows disc. Finally set Sectors to load to 4.
                            7. Click the big create iso button to create the bootable iso.
                            8. And use that iso to burn a new install disc.
                            And this disc works!"
                            Found here: http://forums.macrumors.com/showthread.php?t=467704
                            Didn't try this yet, as I am at the office.
                            • K Offline
                              kwistenbiebel
                              Wow Stinkie...
                              I didn't know installing it was such a hassle.
                              If I had known...
                              Mine came istalled by the Mac Shop where I bought the thing so all was done for me...
                              • StinkieS Offline
                                Stinkie
                                Well, as long as it works, I'm not complaining. We'll see. 😄
                                Also found this. Pretty cheap RAM: http://nl.backoffice.be/shop/details.asp?partid=KTA%2DMP800K2%2F4G
                                I might get me 4 kits (=16gb à € 719,72). Biiiiiiiig renders. 💚
                                  ScottPara
                                  The biggest part of running 64bit is making sure you have all the supporting drivers for any hardware you have or plan to purchase. As it was said though 32bit will soon be a thing of the past and any issues people are currently experiencing will soon go away and or be fixed as the masses got to 64bit.
                                  Scott
                                  Love the fact that some HATE my avatar.....
                                  • StinkieS Offline
                                    Stinkie
                                    To anyone wrestling with the same problem: the method quoted above works. I've just installed Vista Ultimate 64 bit with no problems at all. (No driver related problems so far - but we'll see how that developes.) Tomorrow, I'm gonna get me 16 gb of RAM, and install Indigo and Podium. Yeah! 😍
                                    • StinkieS Offline
                                      Stinkie
                                      Okay ... While Ultimate installed okay, problems have arisen. Not much of a surprise - problems tend to do that. Call me cynical. 😆
                                      Stuff seems to work very slowly. Opening SU takes forever. Opening, say, the SkIndigo render settings thingy in SU does too - SU even becomes comatose for a couple of minutes.
                                      What is this - a drivers related issue? Mind you, I've not installed anything else but Vista, SU and Indigo. What piece, if any, of vital, yes magical software am I missing?
                                      Yup, I really do know squat. 🎉
                                      • K Offline
                                        kwistenbiebel
                                        Have you updated the latest of the latest Geforce drivers?
                                        That did the trick for me.
                                        A slow Sketchup (I mean slower than the slow one we are used to 😄) is very often ill because of GPU drivers not working well together with the software.
                                        By the way, once you got the 64 bit windows thingie running without hickups, you'll be surprised how smooth the performance of the 64 bit version of Indigo is.... It will love your shiny 8 cores 😄
                                        • StinkieS Offline
                                          Stinkie
                                          Hmm ... "videokaartdrivers", you mean? (I know nada about hardware. "Wow! That's called a plow, you say?") Well, if so, I'm in the process of installing the latest for the, erm, GPU I got. I was guessing that was the problem.
                                          I did notice the 64 bit version of Indigo runs real smooth - I loaded a couple of Ono's test files. Pretty impressive.
                                          • K Offline
                                            kwistenbiebel
                                            Indeed 'videokaart drivers' 😄
                                            I don't know which Graph card came with your Mac Pro, but if it is an Nvidia based one you'll probably need these 'Geforce' drivers: http://www.nvidia.com/object/winvista_x64_175.16_whql.html
                                            (worked perfectly for my 8800 GT).
                                            ...But maybe you got one of the ATI based cards... (check your system info).
                                            In that case you'll need the latest 'Catalyst' drivers: http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista64/common-vista64
                                            • 2 / 3
