    XP 64 on an Intel Mac?
    45 Posts 7 Posters 4.4k Views 7 Watching
    • StinkieS
      Stinkie
      The main difference, I think, is that both Ultimate and Business support + 8 GB of RAM, whereas the other 64 bit versions don't.
      Not that I'm gonna install more than 8 GB at the moment, but you never know what the future brings. Me thinks I'm leaving the office early today (boss is out anyway). Gotta go to HCW in Schoten. ๐Ÿ’š They've got Ultimate for 319 โ‚ฌ. http://www.hcw.be/p.aspx?p=H6136
        remus
        Thats a bit lame really, that other versions dont support more than 8GB of Ram, as i would have thought half the point in getting a 64 bit machine is so you can cram it full of ram (if your loaded, of course.)
        • StinkieS
          Stinkie
          Yup, that's lame indeed. And as for prices: that's where I'd choose Windows over Mac any day. ๐Ÿ’š
          • K
            kwistenbiebel
            My God, Is that true? Only 8GB supported in the other versions?
            Thank god I chose Business as I already have 8GB installed and hope to increase the RAM even more in the future when it would be needed...
            (By the way, don't buy Mac RAM...there are other brands 3 times cheaper with the exact same features.)
            • StinkieS
              Stinkie
              Really? Which ones?
              • StinkieS
                Stinkie
                I must correct myself: Home Basic 64 supports 8 gb, Home Premium supports 16 gb, and Ultimate, Business and Enterprise support + 128 gb.
                So Home Premium 64 might be enough for me.
                  remus
                  But how will you ever be able to do 50,000x50,000 renders with only 16gb of ram? You wont stand a chance stinkie, upfrade, you know you want to ๐Ÿ˜„
                  • StinkieS
                    Stinkie
                    Well, Remus, I went shopping, and finally decided upon getting Ultimate, so ... ๐Ÿ’š
                    Anyway, I think 8 gb will last me a while.
                    • StinkieS
                      Stinkie
                      Mornin' SU folk!
                      I tried to install Vista Ultimate 64 bit on my Mac Pro last night, but: no dice. The 32 bit version (which I tried also) installed just fine, but the 64 one ... This is what happened: I started up the Bootcamp Assistant and made me a nice Windows partition. When that was done, the computer rebooted to start the actual installation process (the Vista cd-rom was already in the drive, of course). When it did, it showed me a nice black sceen, with nice white letters on it:
                      Select CD-ROM Boot Type
                      Now, it seems obvious I have to make a choice at this time: 1 or 2. Apart from the fact I have no clue what either of these choices are, I cannot type squat. The computer doesn't respond to the keyboard. ๐Ÿ‘Š
                      Any thoughts? Aphorisms? Poems?
                        remus
                        Ive got to go and et ready for my first exam, might be able to give you a hand when i get back though. A good starting point would be to read this: http://forums.macrumors.com/showthread.php?t=468385
                        • StinkieS
                          Stinkie
                          Thanks for the link. I got all day at the office to dredge trough Mac forums to find a solution for this, erm, interesting problem. ๐Ÿ˜‰
                          Kind of reminds me of the days I enjoyed myself with installing obscure Linux distributions on an old Pentium 3. ๐Ÿ’š
                          Ah, the panic, the stress! ๐Ÿ˜„
                            remus
                            Lol, have you downloaded the latest version of boot camp? (if you can download it, ive never had to try myself)
                            • StinkieS
                              Stinkie
                              I used the version that came with my Leopard install disc. I did get this, though: http://www.apple.com/downloads/macosx/apple/application_updates/bootcampupdate21forwindowsvista64.html
                              Strangely, that's an exe file.
                                remus
                                Do .exe not run on macs then? I havent used a mac for a while and i cant remeber what extension their executables have...
                                • StinkieS
                                  Stinkie
                                  AFAIK, they don't run, no. Now, I'm not worried. A quick Google search taught there's plenty of people out there who experienced the same issue. There's bound to be a solution.
                                  • StinkieS
                                    Stinkie
                                    Some poking around turned up this:
                                    "1. Insert Windows Install disc into DVD drive
                                    2. Using the build mode of imburn, go to the advanced tab, then bootable disc and then select your DVD drive in the extract boot image drop down list. Go ahead and extract the boot image and store it somewhere on your hard drive
                                    3. Go to the information tab and add your DVD drive as the source file
                                    4. Options tab, check that file system is ISO9660 + IDF and UDF revision is 1.02 (should be anyway by default)
                                    5. Go to Advanced tab, sub tab Restrictions and further sub tab ISO9660: Set Folder / File length to Level X and tick the four check boxes at the bottom (allow more than 8 directory levels, Allow more than 255 characters in path, Allow files without Extensions, Donโ€™t Add โ€˜;1โ€™ Version number to Files. (Note itโ€™s this bit that actually solves the problem the rest is effectively just duplicating the existing disc)
                                    6. Move to the bootable disc tab: Click the tick box to make the image bootable, emulation type to โ€œnone (custom)โ€ and the browse and select the boot image you previously extracted from the windows disc. Finally set Sectors to load to 4.
                                    7. Click the big create iso button to create the bootable iso.
                                    8. And use that iso to burn a new install disc.
                                    And this disc works!"
                                    Found here: http://forums.macrumors.com/showthread.php?t=467704
                                    Didn't try this yet, as I am at the office.
                                    • K
                                      kwistenbiebel
                                      Wow Stinkie...
                                      I didn't know installing it was such a hassle.
                                      If I had known...
                                      Mine came istalled by the Mac Shop where I bought the thing so all was done for me...
                                      • StinkieS
                                        Stinkie
                                        Well, as long as it works, I'm not complaining. We'll see. ๐Ÿ˜„
                                        Also found this. Pretty cheap RAM: http://nl.backoffice.be/shop/details.asp?partid=KTA%2DMP800K2%2F4G
                                        I might get me 4 kits (=16gb ร  โ‚ฌ 719,72). Biiiiiiiig renders. ๐Ÿ’š
                                          ScottPara
                                          The biggest part of running 64bit is making sure you have all the supporting drivers for any hardware you have or plan to purchase. As it was said though 32bit will soon be a thing of the past and any issues people are currently experiencing will soon go away and or be fixed as the masses got to 64bit.
                                          Scott
                                          Love the fact that some HATE my avatar.....
                                          • StinkieS
                                            Stinkie
                                            To anyone wrestling with the same problem: the method quoted above works. I've just installed Vista Ultimate 64 bit with no problems at all. (No driver related problems so far - but we'll see how that developes.) Tomorrow, I'm gonna get me 16 gb of RAM, and install Indigo and Podium. Yeah! ๐Ÿ˜
                                            • 2 / 3
