    Cycle Bridge WIP
    16 Posts 14 Posters 2.5k Views 14 Watching
      dylan
      I was asked to model a bridge recently but due to my very busy schedule I had very little time to allocate to it.
      Unfortunatly I did not know it was a helical type shape either when I said I would squeeze it in. I discovered that when I opened the cad plan!
      Thanks to some of the great ruby scripts out their!
      This is a quick sketch after just finishing the basic structure. It still needs tweaking and rendering, then placing in the proposed site.
      Please ignore some of the visual errors where strange things happened with follow me and copy along path. It will only be seen from a distance and I don't have time to perfect it. πŸ˜‰
      http://dmdarchitecture.co.uk/
      • spenceS Offline
        spence
        Now that is nice! I like it.
        Spence
          mike d
          looks good dylan
          mike d
          The grass is always GREENER on the roof.
            mateo soletic
            Nice work Dylan. πŸ‘
            Concept Illustrations
            • boofredlayB Offline
              boofredlay
              Fantastic!
              Show us some different angles if you can. Thanks.
              • DanielD Offline
                Daniel
                "Gee Dylan, I am surprised you would post such a horrible model" Daniel said jokingly, as he admired Dylan's model.
                My avatar is an anachronism.
                • P Offline
                  pav_3j
                  very neat, i like it.
                  wouldn't even know where to begin with doing that.
                  pav
                  Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                  • F Offline
                    fbartels
                    Dylan,
                    Really nice elegant model!
                    If you feel like sharing I'd love to know the major steps in the process you went through to create it.
                    Fred
                    • P Offline
                      pav_3j
                      @fbartels said:
                      Dylan,
                      Fred
                      ooh yeah, that would be pretty cool.
                      πŸ˜‰
                      pav
                        dylan
                        I will share it after I have finished it.
                        My basic steps involved starting with a single helical line which was the path of the bridge at the correct levels.
                        I copied this to a width of 3 metres and used skin.rb. I did try follow me but as you would expect, by the time it reached the opposite side it had rotated so much.
                        I then used Joint Push Pull to give me the 10mm thickness of the walkway.
                        I needed a small upstand on the sides for which I used extend lines ruby, then JPP to give thickness.
                        There is a 300mm central spine beneath the bridge for which I used Offset from Surface.rb, followed by JPP 😍
                        The balustrade was various components rotated into position then used copy along path ruby.
                        It weas my first time using this script and at first I was struggling to get things following this path. It was all down to correctly setting the axis in the component. If you ever use it and you do not get things following the path correctly, then change the components axis.
                        All the cables and handrails were done with Tubealongpath.rb
                        I have never really been a big user of rubies, but recently I have had my eyes opened to their importance, especially with all the new amazing additions that have happened recently and are still coming πŸ‘
                          remus
                          Reallt nice modle dylan, gotta love the design as well, even if it is a bitch to model πŸ˜›
                          • FrederikF Offline
                            Frederik
                            Great model, Dylan..!! πŸ‘
                            Cheers
                            Kim Frederik
                            • marked001M Offline
                              marked001
                              this is great, dylan....love that viewpoint too...
                              http://www.revision21vis.com
                              instagram: revi21on
                              • urgenU Offline
                                urgen
                                ...I look forward πŸ˜›
                                --pupil forever...------
                                  dylan
                                  A small update showing the bridge in context.
                                  I wanted to keep the detail down at this early stage with some basic massing and not much colour.
                                  The buildings behind with green glass were not modelled by me. These are from the Architects who designed the buildings which are currently being constructed.
                                    sepo
                                    Very nice Dylan. I think it would be nice if you could make tutorial out of this.
