    Simple question - how to rotate flat group ?
    5 Posts 3 Posters 828 Views 3 Watching
    • J
      Jorgensen
      How do I rotate an importet section (dwg) or any other flat object, from laying on ground to stading up ?
      I usely draw a 3d-box beside the object, and then use this to rotate via red og green axe. But is there a more simple solution ?
      Jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • P
        pav_3j
        this is how i would do it:
        make the flat section into a component (select all, context click, make component)
        select the move tool, and while hovering over the edge adjacent to the desired direction of rotation, you will see that four red crosses appear.
        placing the move tool over these will give the ability to rotate about that point.
        hope this is helpful?
        pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
        • D
          dylan
          Also in addition to pavs answer, you can use the rotate function, but if you keep your left mouse pressed down once you choose a point of rotation and move the mouse, you can lock onto one of the other axis.
          http://dmdarchitecture.co.uk/
          • J
            Jorgensen
            Wow - thats simple - thank to you both πŸ˜„
            • quit those boxes πŸ˜„
            • P
              pav_3j
              yeah thats probably easier as it goes, always nice to have a component or two in the library though. he he
              pav
