    Incorrect Units when Exporting Slices
    2 Posts 2 Posters 990 Views 2 Watching
    • T
      toxicvoxel
      Maybe somebody can check if they get the same issue:
      When exporting slices from models set up in metric millimeters it exports the file (dwg) as inches.
      (1200mm = 1200 inches).
      I think the exporter is just setting the incorrect unit flag in the file.
      (Admin : If this is a bug then please feel free to move to the bug forum.)
      Model in MM
      [-For some reason I can't seem to upload two attachments.]
      • AnssiA
        Anssi
        Yes I have the same in all DWG exports:
        The units get exported right ( 1 mm in SU = 1 unit in the DWG file)
        BUT
        the scale flags in the DWG file all have Imperial values (Measurement, for instance, is set to 0), so if you have your AutoCad set up to recognize the scale values (as per default), everything gets imported 25.4 times too big.
        I already posted a bug report about this some weeks ago.
        Anssi
