    šŸ¤‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Export SU to SVG
    8 Posts 6 Posters 1.3k Views 6 Watching
    • palyndrokP Offline
      palyndrok
      Hello,
      How I can export sketchup to 2D SVG format?
      Greetings,
      Palyndrok
      • jujuJ Offline
        juju
        Hi, welcome to the forum. SVG format = ?
          remus
          SVG - Wikipedia
          (en.wikipedia.org)
          Check which of those will export SVG, thne find a format they can import that is shared with SU. You will then be able to export from SU into that format, import it in to the other program then export SVG.
          If you dont have the pro version (which contains the exporters) read this: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=9437
          • AnssiA Offline
            Anssi
            I think the most direct route is to export a PDF or EPS from SU, and open that then in an SVG-capable application (Illustrator might do it, have to check Monday). The downside is that textures and shadows cannot be exported.
            Anssi
              palyndrok
              Hi, Juju. SVG means "Scalable Vector Graphic".
              Thanks for your answers
              • jujuJ Offline
                juju
                Thx, just goes to show, everyday can bring new knowledge.
                  dmatho
                  ... and one of the sweetest SVG illustration applications out there is actually free: Inkscape.
                  An item I've requested a while back on the wish-list is that SketchUp be able to export AWA import SVG.
                  Cheers,
                  • Diego -
                  • sketch3d.deS Offline
                    sketch3d.de
                    @anssi said:
                    I think the most direct route is ...
                    ... probably to use SVGmaker
                    Norbert
