    Repaint.rb no longer working?
    5 Posts 2 Posters 703 Views 2 Watching
    • A
      alz
      Repaint is no longer working for me -- is anyone else using this and encountered this problem?
      (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/repaint.rb)
      (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/getMaterials.rb)
      This is a great script for globally swapping materials from one to another. Is there some other way or script that does this?
      • R
        RickW
        That is an old version of Repaint. Get the latest version from Smustard.
        RickW
        www.smustard.com
        • A
          alz
          Hi Rick!
          When you mentioned SMUSTARD I forgot to check which version I had. Sure enough I picked this up from SMUSTARD (v1.1)
          I'm creating a simple test level with 3 rectangles, then applying a different material to each. Without anything selected (or selected), I run Repaint from the plugin menu. Then pick Texture, select material X, then material Y, and okay through the rest of the inputs. No change occurs however
          Am I using the plugin incorrectly?
          (this includes using getMaterials.rb)
          • A
            alz
            Quick follow-up! Realized I had v1.1 and SMUSTARD has v1.2. Picked up latest and greatest and it works.
            • R
              RickW
              Glad you got it figured out. Happy repainting! 😄
              RickW
              www.smustard.com
