    Repaint.rb no longer working?
    5 Posts 2 Posters 609 Views 2 Watching
      alz
      Repaint is no longer working for me -- is anyone else using this and encountered this problem?
      (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/repaint.rb)
      (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/getMaterials.rb)
      This is a great script for globally swapping materials from one to another. Is there some other way or script that does this?
        RickW
        That is an old version of Repaint. Get the latest version from Smustard.
        RickW
        www.smustard.com
          alz
          Hi Rick!
          When you mentioned SMUSTARD I forgot to check which version I had. Sure enough I picked this up from SMUSTARD (v1.1)
          I'm creating a simple test level with 3 rectangles, then applying a different material to each. Without anything selected (or selected), I run Repaint from the plugin menu. Then pick Texture, select material X, then material Y, and okay through the rest of the inputs. No change occurs however
          Am I using the plugin incorrectly?
          (this includes using getMaterials.rb)
            alz
            Quick follow-up! Realized I had v1.1 and SMUSTARD has v1.2. Picked up latest and greatest and it works.
              RickW
              Glad you got it figured out. Happy repainting! 😄
              RickW
              www.smustard.com
