    Problem with my Rendering (Podium) Doesn't show it properly
    extensions
    5 Posts 5 Posters 1.7k Views 5 Watching
    • P
      princep
      Hello. My problem is that, I have a topography, I have extruded some of the buildings. And when I try to do the render, with Podium I get the following results. Do you know what the problem might be and how to solve it? Thanks for you time. PP
      http://img138.imageshack.us/img138/7227/2008041423324638suw9.jpg
      • GaieusG
        Hi princep,
        This in fact seems to me an image still under rendering but I really cannot say more about it without any further details.
        also I'm moving this thread to our Podium subfolder so that Podium users can have a look.
        • I
          igor
          hey, i think your problem is that you didnt let it render! rendering can take a long time in some cases. did you jst pres the render button and save the first thing it spat out? if you use the drop down menu and set the render to "noisy settings" and press the render button and then leav it for about an hour or so, you should be fine. do you happen to be new to podium?
          The genius switch has no "off" position
          Intelegence is natrual, it takes real effort to be ignorant
          • soloS
            solo
            Hmmm..
            The issue is a .dwg import with hidden layers.
            http://www.solos-art.com
            • S
              sepo
              Could you explain that please Solo.
