    Artlantis Studio 2 program crash
    extensions
    5 Posts 3 Posters 1.6k Views 3 Watching
      MPDesign
      When using the 2d window the program crashes. I try add an object to scene and move it in 2d window, crash? I just checked video driver- updated to latest release. I have quicktime 7.4.1 installed. The program hangs now and will not stop hanging. I had to stop it with Windows task manager. Help! :^)
      I forgot to give you my computer specs. Formated hard drive, New install of xp pro sp2. Intel Core 2 quad Q6600 @ 2.4ghz 4 gigs of ram 800mhz speed Bios switched to read more ram says 3.25gb in windows system properties. Nvidia 8600 GTS 512mb PCI-Express (driver version 6.14.11.6939 date-2/1/2008 I have also tried to go back to quick time 6.5.2. Also uninstall reinstall of Art Studio 2. No luck yet same symptoms: computer freezes, no mouse or key board no commands possible and I have to use the power switch to reboot. Thank you, I will post more info as found.
      I am wondering if anyone has an idea on what to do next with this machine?
      Thank you for reading this request,
      Michael
      http://www.MichaelPachDesign.com
        Sjaak
        Michael,
        Your config looks OK. One thing I can think of.....The latest version of Quicktime seems to be not too stable. I heard more complaints and not only in combination with ArtLantis. You could try to return to the previous version and see what happens. I still have 7.3.1 and averything works fine.
        Please let us know what happens.
        Sjaak
        Artlantisobjects.com
        the best resource for artlantis
        with the best deals
          ScottPara
          Micheal,
          It may be the complexity of the scene also. I have had artlantis 1.2 and 2 crash on complex scenes when trying to move an object in 2D. I alos would suggest reloading an older version of the file and try that. I know it is not what you want to hear but it may be the only alternative.
          Scott
          Love the fact that some HATE my avatar.....
            MPDesign
            Hi Sjaak & Scott,
            I apologize I didn't respond sooner. I have discovered the problem.
            It seems it is video card related.
            I went and opened a small project and went to the edit-options menu.
            I unchecked use open GL and thats it,fixed! 😍
            I have no idea why but it works so I can work again. πŸ˜„
            Thank you,
            Michael
            http://MichaelPachDesign.com
              ScottPara
              Well the good thing is you are back up and running.
              Scott
