    Sketchyphysics animation in scenes?
    5 Posts 4 Posters 3.4k Views 4 Watching
    • K Offline
      kwistenbiebel
      Hi there,
      I would like to render a sketchyphysics animation from classic scenes('pages' in SU 5).
      Is that possible?
      It would be great if the SP animation would automatically create a 'scene' per frame.
      Thanks in advance,
      Kwistenbiebel
        I am afraid that is not yet possible! 😮
        Solution is use prog like Camstasia 😉
        For the render seems impossible 😞
        Sketchyphysics 3?
        • K Offline
          kwistenbiebel
          You might want to check this:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=8587
          That animation is done with Indigo and it uses the classic animation sequence deriving from the 'scenes' in sketchup.
          If SketchyPhysics could write a 'scene' for every frame, I could start rendering bouncing balls photoreal 😄
          Cheers,
          Kwistenbiebel
            CPhillips
            I guess I could save the model each frame. But it would be slow. Perhaps in SP3.
            Someone in the main thread was asking about a SU2KT exporter for SP. That might be possible.
              anglaret
              Kwiesten
              I exactly double your search for animation
              There is a little skp called "advance" made by sarnam, that I do not find again, where a little 3-cylinder car goes on around a scene.
              It looks exactly how I would like to have a car running through a project to create animation.
              I tried to manage SUphysics to imitate... without success
              Marc
