Sketchyphysics animation in scenes?
Hi there,
I would like to render a sketchyphysics animation from classic scenes('pages' in SU 5).
Is that possible?
It would be great if the SP animation would automatically create a 'scene' per frame.Thanks in advance,
Kwistenbiebel -
I am afraid that is not yet possible!
Solution is use prog like Camstasia
For the render seems impossible
Sketchyphysics 3? -
You might want to check this:
http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=8587That animation is done with Indigo and it uses the classic animation sequence deriving from the 'scenes' in sketchup.
If SketchyPhysics could write a 'scene' for every frame, I could start rendering bouncing balls photoreal
Cheers,
Kwistenbiebel -
I guess I could save the model each frame. But it would be slow. Perhaps in SP3.
Someone in the main thread was asking about a SU2KT exporter for SP. That might be possible.
Kwiesten
I exactly double your search for animation
There is a little skp called "advance" made by sarnam, that I do not find again, where a little 3-cylinder car goes on around a scene.
It looks exactly how I would like to have a car running through a project to create animation.
I tried to manage SUphysics to imitate... without success
Marc
