    Camera clipping issue
    2 Posts 2 Posters 402 Views 2 Watching
    • J
      j_forrester
      Hi Guys,
      Just a quick one. I have just imported a DWG into sketchup and scaled it correctly. The only problem is when I zoom in it seems to clip the model and therefore not able to get close enough in to snap to certain points? (Version 6 Pro)
      Not sure if anyone else has experienced this before.
      Many thanks in advance
      • GaieusG
        Hi J,
        This is a know issue in SU (in fact you even got the "name" of it right), please, read this article about possible solutions.
        Also, if your model (area) should not be as big as described above, make sure there are no "stray lines" (resulted from sloppy drawing in a CAD program) somewhere far-raf away. Even a couple of cms/inches line fragments can cause this.
        Edit: the easiest way to find some remote stray lines that may be the "culprit" is to "Select all" (Edit menu or the "classical" Ctrl+A) and then zoom to extent. You will see odd selections far away (provided that you are in an editing context of a possibly grouped geometry).
