    Ionic Column
    10 Posts 6 Posters 3.4k Views 6 Watching
      Julius
      i hope this is the right place to post this.
      this is my first attempt to model a ionic column. the tutorial by Gaieus helped me in modeling the flutes, whereas for the tapering i just scaled down the top a bit.
      below is a quick render with podium.
      http://img442.imageshack.us/img442/2352/2008032813324054sew2.jpg
      this model @ the 3DWarehouse.
      Updated version
      • F Offline
        fbartels
        Julius,
        Very nice model. The details are excellent! If you ever feel like it I'd enjoy seeing a tutorial on how you made it.
        Thanks for sharing.
        Fred
          Julius
          i don't know if i'll manage to make it a second time, but if i find the time i will try.
          p.s.: thank you for your tuorials about the TIN tube, it's very helpful!
            Hi Julius,
            Great model! Thanks for sharing! 👍
            I might play around with it at some scenes I1m planning to do in Kerky. 😉
              Baker518
              very nice, clean look
              Don't worry about things you have no control over. Worry is a lack of Faith!
                Julius
                i rendered a group of my ionic columns in KT.
                i share it even though it's nothing special.
                http://img134.imageshack.us/img134/5579/ioniccolumnssp8.th.jpg
                  Julius
                  a great thank to the "two Bob" who are helping me in reducing the size of the column! 😄 i really appreciate it!
                  • G Offline
                    GreyHead
                    Julius asked to know how to reduce the size of the bases of the column. Here's a little (actually quite big) tutorial.
                    I developed this technique from playing with the wooden clock model. Converting the gears on that into components reduced the model size by about half from 8Mb to 4Mb.
                    The same is true for Julius' column. The tutorial works on the base and creates a higher poly smaller sized version. Which is more important will depend on the model I guess.
                    Original: 2,592 faces, 1,253 edges, 213kb file
                    Final: 11,856 faces, 5,112 edges, 49k file
                    NB the high poly version before splitting into components comes in at
                    10,386 faces, 4,997 edges, 885kb file size!
                    Bob
                    Original on the left, final on the right.
                    segments_tut.zip
                      Julius
                      thanks! i didn't understand why yours had more faces, but now i see that you used a circle with 96 segments, whereas i used the default one with 24 segments.
                      i updated the model in the first post too. the original size was 1,65 MB, now it's 685 KB! ☀
                      • P Offline
                        pichuneke
                        I have some Ionic colums done, the classical one and italic (a variation). If you want them send me a pm with yuor email and I will send you them (They are part of my unreleased (yet) project of the roman theatre of Cartago Nova).
                        Forgive my spanglish...
