    Where have all the textures gone?
    extensions
    2 Posts 2 Posters 1.1k Views 2 Watching
    • R
      Roger
      I have lost the textures in one of my KT renders.
      As a check on what was happening I then made another render of just a rectangle with one of the textures applied. It worked fine. Then I opened the xml on both files and looked for glaring errors such as different paths or differences in the texture name. Nothing jumped out at me as being incorrect. I hate to go back and try to rebuild the whole project.
      Has anyone experienced the problem or does anyone have ideas on why this would happen?
      This is the KT file with lost or mangled textures.
      This is the SU file prior to export
      http://www.azcreative.com
      • FrederikF
        Frederik
        Hi Roger,
        I suggest that you simply put your XML-file in the same folder as your textures... This will ensure that KT will find them... πŸ˜‰
        Did you re-export your model - or part of it - and then use the "merge" tool..?? πŸ˜•
        It seem as if you've exported this scene with the Export default UVs set to "YES"...
        If this is the case I suggst that you re-export again with "No" instead...
        Cheers
        Kim Frederik
