    [Plugin] SketchyFFD Free Form Deformation.
    2 Posts 2 Posters 28.4k Views 2 Watching
      CPhillips
      Ruby plugin to do Free Form Deformation of geometry. A pictures worth a thousand words.
      http://sketchyphysics2.googlecode.com/files/wolfman.gif
      Install by putting the script in your plugins directory.
      Instructions:
      -Create a group with all the geometry you wish to deform. This group should contain just faces and/or lines.
      -Right click the group and select either 2x2 or 3x3 FFD. Depending on the size of the model it could take a while (seconds I hope). At the end you should see a new group containing nothing but control points
      -Open the group and move the control points as you wish.
      -Right click and select Update FFD. Group should deform. Again it make take seconds to minutes to finish depending on the size of the model.
      -You can press Undo or you can continue to refine the control points. Make sure you close control point group before updating.
      Bugs and limitations:
      -BUG. If you start a FFD and the control points don't match the object you need to explode and regroup the object. Then try the FFD again.
      -Only one FFD at a time. The script uses a few globals for speed.
      -Only works on geometry in a group and only one layer deep.
      -Sometimes hidden edges don't move right. Dont know why. Might be a bug in Sketchup.
      http://sketchyphysics2.googlecode.com/files/BendingADeer.gif
      Update: Fixed a bug.
      Update Feb 12. New version:
      -Support for NxN deforms.
      -Mesh automatically when you move control points.
      -Added status text progress when it is weighing and deforming the mesh.
      Update Mar 21.
      -Moved all FFD right click menu items to a sub menu.
      -Fixed a bug that forced you to have a least 2 control point in each direction. You can now have do 2D grids. IE. 1x4x3.
      -Added an option to create a NxN 2d patch. A grid with a control point at each intersection.
      EDIT:
      There is much more up to date version available from the newer main thread here http://forums.sketchucation.com/viewtopic.php?p=36127#p36127 - this original version is left here only 'for interest'... TIG
      OBSOLETE !
        sawhack
        did you make the monster head using only this ruby script? can you make a complete tutorial for that organic shape? FFD i only found it in 3ds max and you make for sketchup great plugins
        thanks
