    Help with getting my gun smoother
    15 Posts 7 Posters 2.4k Views 7 Watching
      jimutt
      Hi! I'm quite new in SketchUp and for the moment I'm trying to modeling a HK MP5.
      And now I'm going to make the smoother things like the grip and so on. But i want to know the easiest way to do that.
      • G Offline
        GUNAWAN W
        Hi Jim, please attach the picture first so i can see what it is.
        so actualy if you want to smooth the face, just simply select your component, and go to the Window > soften edge and you can make it smoother as your like.
        BR
          jimutt
          Yeah, I know I can use the soften edges tool but some parts of the gun I want to do smoother than with the soften edges tool. But here's a picture of the model.
          • Alan FraserA Offline
            Alan Fraser
            You'll never get the gun smooth by simply tracing around it and extruding. You will need to import the photo then use it as a template to construct the gun the way it is...in other words, using the circle tool and Push/Pull on the barrel, sights and parts of the stock etc.
            When you have finished actually constructing it, you can pull the photo away from the model, (but still lined up with it) sample the photo, then project it onto the mesh.
            This horse was done exactly that way in SU. It uses a single, side-on image.
            3D Figures
              jimutt
              Hmm, I think youre right. But it will be much harder to do it on the "real" way. ๐Ÿ˜•
                Alan Fraser
                This is the start of what I mean. The lower photo has been exploded, sampled and painted onto the gun. Only model half the gun, then duplicate, mirror and stick the two halves together.
                mp5.skp
                3D Figures
                • G Offline
                  GUNAWAN W
                  hmmm. i think you should see this thread http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=5687#p32591
                  but right now the ruby is not available.
                  anyway I'm agree with alan.
                  hai Alan,
                  can you show me how to make a horse model from single image?
                  screen shoot or the model? ๐Ÿ˜ฎ
                  • P Offline
                    Pagan
                    How to make a smoother curve...
                    video demonstration: http://www.speedyshare.com/655417782.html
                    Here,take this,smoother cylinder shape...
                    • chippwaltersC Offline
                      chippwalters
                      I must be missing something here. Why wouldn't you just change the number of segments in the arc before drawing it?
                      Currently working with Cross-Reality technologies
                      • P Offline
                        Pagan
                        Change,but where...
                        http://dhost.info/pagan/emo3/022.gif
                          chippwalters
                          When you click on the arc tool, look in the VCB (lower right) and it will tell you how many segments the arc will have. You can change the number, press enter, and the next arc will draw with the new number of segments.
                          • P Offline
                            Pagan
                            Thanks...didn't know that... ๐Ÿ‘
                              You can also right click > entity info and if you haven't modified it yet, you can overwrizte the segment number. If not, it is already greyed out.
                                Clarencecat
                                can you tell me why i don't have access to pics here?
                                  Clarencecat
                                  H
                                  i see it's working now
