    Configuring Model Info i.e precision & length snapping
    2 Posts 2 Posters 577 Views 2 Watching
    • H
      heinz_ketchup
      Under Model Info >> Units >>
      I am looking at two of the fields
      1. Precision
      2. Length Snapping
      Ok, to start I am working under Architectural
      How does 1) and 2) work?
      My Situation.
      The default on mine was 1/16" for precision and 1/4" Length Snapping.
      I am designing a jig saw guide and need to work with 32nds of an inch.
      The problem I am running into is when I used the ruler for precision 32nds, it shows the correct placer, but when I go to draw a line it does not let me connect two points.
      Any help would be greatly appreciated.
      • GaieusG
        Do you mean that when trying to draw a line between two points, the line itself is not created or there is no face created when the line is drawn?
        There is a glitch in SU when it comes to very small models; under about 1/16" it won't create faces properly. The general workaround is to draw your geometry in a bigger scale (in metric it's easy, say 10 times bigger) and after you finished, scale your model back to the desired size.
