    [Plugin] Default Layer | Tag Geometry
    27 Posts 15 Posters 29.2k Views 15 Watching
    • pbacotP Offline
      Great! Thanks!
      • TIGT Online
        Here's v2.1 http://sketchucation.com/pluginstore?pln=default_layer_geometry It is further optimized by correcting a stupid typo 😲
          jwhida
          Hi TIG,
          when I try to use the script the following error appears in console (see below). I am using SU2018, and I note you have not listed it as supported.
          I believe line 88 should be
          self.zero( e.entities )
          rather than
          self.zero( e )
          Error: #<NoMethodError: undefined method each' for #<Sketchup::Group:0x0002850e51d778>> C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:in zero'
          C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:88:in block in zero' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:in each'
          C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:in zero' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:84:in block in zero'
          C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:in each' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:69:in zero'
          C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:48:in new' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/default_layer_geometry.rb:35:in block in module:DefaultLayerGeometry'
          SketchUp:1:in `call'
          • TIGT Online
            I think you are correct.
            Try changing that line as you indicated - it should then work with selected Groups...
            There are other newer and more compatible plugins, like my LayerWatcher, which do similar things and more besides...
            • TIGT Online
              I've made v3.0 which is pretty much unchanged, except that in newer SketchUp versions it uses the word 'Tag' instead of 'Layer'...
              https://sketchucation.com/pluginstore?pln=default_layer_geometry
              • F Offline
                fuzzyderango
                Great plugin! Any way to also untag nested groups and components? So that only the "outer most" group/component has a tag? I think you mentioned that your LayerWatcher script did something similar but that seems to also explode those entities? Thanks!
                • TIGT Online
                  Why not edit the container and select-all, then run the tool to untag the selected contents.
                  The outermost container's tag should be unchanged by this...
                  • 2 / 2
