Select all geometry
Hello
I am working on a little script that is moving groups or components based on offset values read from a txt file and saving the files again at the new location.
Script is working but now I want to get things done without having to manually "select all".
I have looked everywhere for inspiration but without luck.
Can anyone help with this?
What I need is a way for the script to select all geometries in a open active file. Is this possible? -
I guess you need to perform your loop exploration of entities on
Sketchup.model.active_entitiesinstead of
Sketchup.model.selectionThis will be thus independent from the selection
Thanks.
I am kind of new to ruby scripting so I am not sure of what you mean!
You suggest that I set up a kind of loop that goes through the model and selects all the components?
Can you suggest a method for doing this?
If you want to collect all compos instances and groups in your model and select them:def select_comps @sel=Sketchup.active_model.selection @sel.clear #prevents any wrong previous selection Sketchup.active_model.active_entities.each { |ent| @sel.add ent if (ent.typename == "ComponentInstance") or (ent.typename == "Group") } endThere are other ways to do this (yeld method for instance) but this one may be more understandable.
Use "select_comps" at the beginning of your script and all instances will be ready in @sel variable for further action(s):def my_script
select_comps
endHope this helps,
Hi Didier
Thank you very much. It works perfectly!
In one line:
Sketchup.active_model.selection.add(Sketchup.active_model.entities.to_a)No need to clear it first.
Todd
What I meant is that you do not need to select entities to perform your 'move' operations. Sketchup.active_model.active_entitiescontains all the entities of the model, and you can then apply your transformation to this list.
For instance, if you want to move all objects of the model by an offset offset_vector (which you'll read from a file), then all you have to write is
all_entities = Sketchup.active_model.active_entities #all entities of the models t = Geom;;Transformation.translation offset_vector all_entities.transform_entities t, all_entitiesNow, if your problem is about the selection, Todd's and Didier's code will make it as a Select All.
In one line:
> Sketchup.active_model.selection.add(Sketchup.active_model.entities.to_a) >Please, Todd, tell me how to select my object »Stein«, but not all entities.
In select_all function, replace@sel.add ent if (ent.typename == "ComponentInstance")with:
@sel.add Sketchup.active_model.definitions["Stein"].instancesassuming that you want to select all instances of the "Stein" component, I guess.
If I had to code such a function, I'll write this:
def select_comp_by_name(comp_name) @sel = Sketchup.active_model.selection @sel.clear! @sel.add Sketchup.active_model.definitions[comp_name].instances @sel endFunction call example in the script:
... stones=select_comp_by_name("Stein")Hope this helps,
def select_comp_by_name(comp_name) @sel = Sketchup.active_model.selection @sel.clear! @sel.add Sketchup.active_model.definitions[comp_name].instances @sel endFrom this I made a text file "Aar_select_comp_by_name.rb" in the Plugins folder. Restart SU.
stones=select_comp_by_name("Stein")This I wrote in the ruby console line.
Then comes the following error:
Error: #<NoMethodError: undefined method `clear!' for #Sketchup::Selection:0x1afaa3b0>
(eval):11
(eval):11How to select an object by name?
Unfortunately I don’t know, what to type in the Ruby console line (I am Ruby beginner).
Just remove the exclamation mark to @sel.clear
Then come the following error:
@unknownuser said:stones=select_comp_by_name("Stein")
Error: #<NoMethodError: undefined method `instances' for nil:NilClass>
/Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:4
(eval):197 -
First, I would make a test on the return value of Sketchup.active_model.definitions[comp_name], because if there is no such component definition*<comp_name>*, it will return <nil>, and applying the method instanceswill provoke an error.
Otherwise, your code seems correct to me.
The issue is maybe that there is no such component "Stein" in your model. You should check with the Component window.
Error: #<NameError: undefined local variable or method `comp_name' for main:Object>
(eval):197This comes from ruby console.
I had an object named "Stein". And your question to a component named ”Stein" let me make also a component named "Stein". Same error.
When you call it from the console, use "stein" not comp_name, which is the name of the variable. So:
Sketchup.active_model.definitions["stein"]Your code looks correct. Here it is with the test on existence of the component
def select_comp_by_name(comp_name) model = Sketchup.active_model sel = model.selection sel.clear compdef = model.definitions[comp_name] if compdef #There is a component sel.clear sel.add compdef.instances else UI.beep end endAre you sure you have a component called "stein" in your model? Check with the Windows>Components. By the way, I wonder what you call "an Object named "stein"", as in Sketchup, you only give a name to Components or Groups, but there is nothing like an 'object'.
Note also that Sketchup is not case sensitive with the name of components.
Fredo
…Please excuse me, I have a group named "Stein", no object.
Then, this is the source of your error.
You must have a Component, not a Group for your Ruby code to work.
In Sketchup, use the command Make Component(shortcut 'G') instead of Make Group -
@Fredo6
Now my model has no group "Stein", but one component "Stein". But I have no luck. To select my component "Stein" by script in ruby console does not work. Did you try your script lines and you could select your component by name? -
Which error do you get?
Register LoginAdvertisement
