    Select all geometry
    29 Posts 6 Posters 3.2k Views 6 Watching
    • L
      Laxmarsk
      Hello
      I am working on a little script that is moving groups or components based on offset values read from a txt file and saving the files again at the new location.
      Script is working but now I want to get things done without having to manually "select all".
      I have looked everywhere for inspiration but without luck.
      Can anyone help with this?
      What I need is a way for the script to select all geometries in a open active file. Is this possible?
      • fredo6F
        I guess you need to perform your loop exploration of entities on
        Sketchup.model.active_entities
        instead of
        Sketchup.model.selection
        This will be thus independent from the selection
        • L
          Laxmarsk
          Thanks.
          I am kind of new to ruby scripting so I am not sure of what you mean!
          You suggest that I set up a kind of loop that goes through the model and selects all the components?
          Can you suggest a method for doing this?
          • Didier BurD
            Didier Bur
            If you want to collect all compos instances and groups in your model and select them:
            def select_comps
            @sel=Sketchup.active_model.selection
            @sel.clear #prevents any wrong previous selection
            Sketchup.active_model.active_entities.each { |ent|
               @sel.add ent if (ent.typename == "ComponentInstance") or (ent.typename == "Group")
            There are other ways to do this (yeld method for instance) but this one may be more understandable.
            Use "select_comps" at the beginning of your script and all instances will be ready in @sel variable for further action(s):
            def my_script
            select_comps
            Hope this helps,
            DB
            • L
              Laxmarsk
              Hi Didier
              Thank you very much. It works perfectly!
              • T
                todd burch
                In one line:
                Sketchup.active_model.selection.add(Sketchup.active_model.entities.to_a)
                No need to clear it first.
                Todd
                • fredo6F
                  What I meant is that you do not need to select entities to perform your 'move' operations. Sketchup.active_model.active_entitiescontains all the entities of the model, and you can then apply your transformation to this list.
                  For instance, if you want to move all objects of the model by an offset offset_vector (which you'll read from a file), then all you have to write is
                  all_entities = Sketchup.active_model.active_entities   #all entities of the models
                  t = Geom;;Transformation.translation offset_vector
                  all_entities.transform_entities t, all_entities
                  Now, if your problem is about the selection, Todd's and Didier's code will make it as a Select All.
                  • N
                    N Lindenthal
                    In one line:
                    Please, Todd, tell me how to select my object »Stein«, but not all entities.
                    • Didier BurD
                      Didier Bur
                      In select_all function, replace
                      with:
                      @sel.add Sketchup.active_model.definitions["Stein"].instances
                      assuming that you want to select all instances of the "Stein" component, I guess.
                      If I had to code such a function, I'll write this:
                      def select_comp_by_name(comp_name)
                      @sel = Sketchup.active_model.selection
                      @sel.clear!
                      @sel.add Sketchup.active_model.definitions[comp_name].instances
                      @sel
                      Function call example in the script:
                      stones=select_comp_by_name("Stein")
                      Hope this helps,
                      DB
                      • N
                        N Lindenthal
                        @Didier
                        @sel.clear!
                        @sel
                        From this I made a text file "Aar_select_comp_by_name.rb" in the Plugins folder. Restart SU.
                        This I wrote in the ruby console line.
                        Then comes the following error:
                        Error: #<NoMethodError: undefined method `clear!' for #Sketchup::Selection:0x1afaa3b0>
                        (eval):11
                        (eval):11
                        How to select an object by name?
                        • N
                          N Lindenthal
                          Unfortunately I don’t know, what to type in the Ruby console line (I am Ruby beginner).
                          • fredo6F
                            Just remove the exclamation mark to @sel.clear
                            • N
                              N Lindenthal
                              Then come the following error:
                              Error: #<NoMethodError: undefined method `instances' for nil:NilClass>
                              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/Aar_Select_comp_by_name.rb:4
                              (eval):197
                              • fredo6F
                                First, I would make a test on the return value of Sketchup.active_model.definitions[comp_name], because if there is no such component definition*<comp_name>*, it will return <nil>, and applying the method instanceswill provoke an error.
                                Otherwise, your code seems correct to me.
                                The issue is maybe that there is no such component "Stein" in your model. You should check with the Component window.
                                • N
                                  N Lindenthal
                                  @Fredo6
                                  Error: #<NameError: undefined local variable or method `comp_name' for main:Object>
                                  (eval):197
                                  This comes from ruby console.
                                  I had an object named "Stein". And your question to a component named ”Stein" let me make also a component named "Stein". Same error.
                                  • fredo6F
                                    When you call it from the console, use "stein" not comp_name, which is the name of the variable. So:
                                    Sketchup.active_model.definitions["stein"]
                                    Your code looks correct. Here it is with the test on existence of the component
                                       model = Sketchup.active_model
                                       sel = model.selection
                                       sel.clear
                                       compdef = model.definitions[comp_name]
                                       if compdef  #There is a component
                                          sel.clear
                                          sel.add compdef.instances
                                       else
                                          UI.beep
                                    Are you sure you have a component called "stein" in your model? Check with the Windows>Components. By the way, I wonder what you call "an Object named "stein"", as in Sketchup, you only give a name to Components or Groups, but there is nothing like an 'object'.
                                    Note also that Sketchup is not case sensitive with the name of components.
                                    • N
                                      N Lindenthal
                                      Please excuse me, I have a group named "Stein", no object.
                                      • fredo6F
                                        Then, this is the source of your error.
                                        You must have a Component, not a Group for your Ruby code to work.
                                        In Sketchup, use the command Make Component(shortcut 'G') instead of Make Group
                                        • N
                                          N Lindenthal
                                          @Fredo6
                                          Now my model has no group "Stein", but one component "Stein". But I have no luck. To select my component "Stein" by script in ruby console does not work. Did you try your script lines and you could select your component by name?
                                          • fredo6F
                                            Which error do you get?
