@ TIG: default layers question
Hi TIG,
I dont understand that:if Sketchup.active_model.selection[0] UI.messagebox("Default All Layers;\nSelect Objects BEFORE Running.") return nilIf there's at least an object selected, why this ?
I could give you the complex answer or the simple one...
To be honest it's a simple typo !!! Should be "if NOT selection" etc... Sorry...
Another typo crept in too ! In the menu so v1.2 is now here...
I've re-re-loaded the script here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=46829#p46829
The original thread(s) are deleted...
Register LoginAdvertisement
