    Change Color of a model
    5 Posts 3 Posters 870 Views 3 Watching
    • G
      gogcam
      Hey there
      I got a little question about changing the color of a model...
      I have generated a table with ruby. Now I want to change the color or/and the material of it.
      How can I do that?
      Thanks a lot
      Cheers,
      gogcam
      • G
        Gjenio
        You can use either color by layer (from the layer window) or just use the paint bucket tool choosing the material you want to apply
        • T
          todd burch
          You can do it two ways, depending on how you have made the table.
          The if the table is a group or component (g/c), you can apply a Material (or Color) to the g/c. If not, you can apply the Material or Color to each face (and/or edge). If you get stuck, post some code.
          Todd
          • G
            gogcam
            w = 2500.mm
            d = 2000.mm
            h = 1000.mm
            pts = [[0,0,h-40.mm], [w,0,h-40.mm], [w,d,h-40.mm], [0,d,h-40.mm]]
            base = container.add_face pts
            h = -h if base.normal.dot(Z_AXIS) < 0.0
            base.pushpull 40.mm
            Thats the main code for the base of the table. Sadly I have no clue how I can change the material or color of it. I googled a lot but somehow I didnt find anything really useful for a ruby newbie like me 😞
            Thanks for your help!
            gogcam
            • T
              todd burch
              Try this:
              w = 2500.mm
              d = 2000.mm
              h = 1000.mm
              group = Sketchup.active_model.entities.add_group
              container = group.entities ;
              base.pushpull 40.mm
              group.material = "red" ;
              Todd
