    Change Color of a model
    5 Posts 3 Posters 808 Views 3 Watching
      gogcam
      Hey there
      I got a little question about changing the color of a model...
      I have generated a table with ruby. Now I want to change the color or/and the material of it.
      How can I do that?
      Thanks a lot
      Cheers,
      gogcam
        Gjenio
        You can use either color by layer (from the layer window) or just use the paint bucket tool choosing the material you want to apply
          todd burch
          You can do it two ways, depending on how you have made the table.
          The if the table is a group or component (g/c), you can apply a Material (or Color) to the g/c. If not, you can apply the Material or Color to each face (and/or edge). If you get stuck, post some code.
          Todd
            gogcam
            w = 2500.mm
            d = 2000.mm
            h = 1000.mm
            pts = [[0,0,h-40.mm], [w,0,h-40.mm], [w,d,h-40.mm], [0,d,h-40.mm]]
            base = container.add_face pts
            h = -h if base.normal.dot(Z_AXIS) < 0.0
            base.pushpull 40.mm
            Thats the main code for the base of the table. Sadly I have no clue how I can change the material or color of it. I googled a lot but somehow I didnt find anything really useful for a ruby newbie like me 😞
            Thanks for your help!
            gogcam
              todd burch
              Try this:
              w = 2500.mm
              d = 2000.mm
              h = 1000.mm
              group = Sketchup.active_model.entities.add_group
              container = group.entities ;
              base.pushpull 40.mm
              group.material = "red" ;
              Todd
