    To TIG:random delete
    9 Posts 3 Posters 1.5k Views 3 Watching
    • R
      rv1974
      Hi TIG!
      Could be delete easily replaced with CUT? Cut and place I mean.
      Thanks in advance.
      • TIGT
        @rv1974 said:
        Hi TIG!
        Thanks in advance.
        You can't Ruby script the basic Edit commands like Cut/Copy/Paste. However you could make a RandomSelect script that would go through the selection and randomly select a %, you could then Cut them (Ctrl+X) and re-paste etc...
        I'll publish a version shortly...
        • TIGT
          Here's the requested RandomSelect script: http://www.sketchucation.com/forums/scf/viewtopic.php?p=44671#p44671
          • GaieusG
            That was quick, TIG! πŸ‘
            • R
              rv1974
              74 minutes 😎
              Thanks TIG!
              • TIGT
                Actually it was only ~14 minutes - I didn't read your question for the first hour !!!
                Does it do what you wanted ?
                • R
                  rv1974
                  Yes definitely. Randomly positioned elements in elevations, light sourses,
                  trees to be scaled- there is a wide field for implementation.
                  Thanks once again!
                  • R
                    rv1974
                    Hi TIG!
                    Are you sure you uploaded the right file?
                    • TIGT
                      I did upload the correct file... BUT the weirdness of Vista is that it segregates 'compatibility files' when they're inside the Programs Files Folder.
                      I based RandomSelect on RandomDelete. I copied it, renamed it and changed its contents - and when I used it it read the right one and runs fine !!! BUT for some stupid reason Vista uploads the initial unedited copy - although it has the right 'name'...
                      After some efforts I have fixed it and I have now corrected the error in the Depository...
                      The old version needs deleting but I can't do it since after a day or so the posts seem to be locked... Can a Mod please fix.
                      EDIT: As of this edit the wrong file/post is gone. Anyone who downloaded the duff version (~24 ?) please accept my apologies, and go and get the corrected one...
                      More haste, less speed...
