    Cannot select faces T-T
    5 Posts 4 Posters 1.3k Views 4 Watching
      dlsf
      I know what's the problem, it's my cheap Intel onboard display card.....
      I tried go to Windoes > preference > openGL > disable hard acceleration, then everything just work fine, but it slows down my SU very very much =(
      when i turn the hardware acceleration ON, then i have the face selecting problem ( it always select the face behind it)...
      so the only thing i can do is to buy a new graphic card? Please help~ 😒
      p.s. I am using window XP SP2
      • P Offline
        pmiller
        Unfortunately Intel Integrated graphics simply do not work with hardware acceleration -- you need a proper graphics card.
          dlsf
          thanks for fast reponse πŸ‘
          I will go get a new graphic card tomoorow 😒
            StarWarsKnower
            You don't need a new graphics card at all, go on to Window>Preferences>OpenGL>Correct reversed picking driver bug. Easy fix!
            Mike
            • AnssiA Offline
              Anssi
              AFAIK doesn't help with Intel cards, but has worked with older ATI ones.
              Anssi
