    Load file
    4 Posts 3 Posters 929 Views 3 Watching
      rubine
      path=Sketchup.find_support_file "rectangle#1.skp"
      does not work, even if I add the full path of the skp file as second parameter
      Does someone have an idea why this does not work??
      If I put the skp file in the plugin folder it does not work either.
        Jim
        rubine,
        It looks like the optional folder argument is not optional. It finds the file if it is in the "Sketchup 6" folder. So, I guess it doesn't actually find the file for you. Sounds like a bug to me.
        path = Sketchup.find_support_file "rectangle#1.skp", "Plugins"
        or
        path = Sketchup.find_support_file "Plugins/rectangle#1.skp"
        Although I don't know if the second example is portable.
        And the documentation is incorrect where it says it returns false - it return nil.
          path = Sketchup.find_support_file "/Plugins/rectangle#1.skp"
          works (with /), as does...
          IF it's in the base SUp folder
          (PC only)
            rubine
            is there also a possibility to store components automatically in a folder (as an .skp file)?
