    S.I.D. - Space Intruder Detector
    17 Posts 7 Posters 5.3k Views 7 Watching
    • Al HartA
      Al Hart
      http://nxt.accurender.com/photos/sketchup/images/2346/original.aspx
      S.I.D. - Space Intruder Detector (1970) by COSEDIMARCO from Google 3D Warehouse
      (1st Place in the Google SketchUp 3D Challenge #013)
      • rendered with IRender nXt using AccuStudio "Torn Clouds" HDRI sky.
        http://wiki.renderplus.com/index.php?title=IRender_nXt
      • all light materials in model set as metal
      • 13 passes - 2 minutes
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • R
        Ross Macintosh
        Render looks good Al and great to see it rendered quickly. It of course is a little odd to have it with that background. If you have time to play with it more it would be cool to see it in a space environment.
        Regards, Ross
        • Al HartA
          Al Hart
          I did the rendering to demonstrate the quality of the HDRI lighting and reflection.
          I should place support poles around the satellite so it makes sense on the ground.
          I can also turn off the sky itself and only use it for reflection.
          Here are a couple more views:
          http://www.renderplus.com/images/sid2.jpg
          http://www.renderplus.com/images/sid3.jpg
          Al Hart
          • R
            remus
            really like the last one al, looks aout as real as something floatign aobut in orbit ever can.
            • R
              Ross Macintosh
              That last one is really cool. 😎
              • AnssiA
                Anssi
                Except that the light in real photographs is much more harsh than this-there is no sky to soften the shadows...
                Anssi
                • L
                  lewiswadsworth
                  You all realize that this was a vehicle (actually, a floating AI designed to detect the organ-stealing, green-skinned aliens before they did their dirty work) from Gerry Anderson's U.F.O. television series, from Britain, in the early 1970's?
                  A seriously odd show, even by the standards of the day...moonbases that looked like soccer balls, phallic Interceptors that fired nuclear missiles shaped like bloated cigarettes, gull-winged turbine-powered cars, female SHADOW officers who wore purple wigs as part of their uniforms...the goodness goes on and on.
                  The "actual" SID was white with red trim.
                  col sporcar si trova
                  • Al HartA
                    Al Hart
                    From this view, the satellite would only reflect the sun. I have it reflecting more sky.
                    But I was trying to make a pleasing rendering, not a photograph. And to show how nice these SketchUp models can look when rendered with a little reflection. 😉
                    Anssi
                    Al Hart
                    • R
                      remus
                      new favourite 👍
                      • R
                        remus
                        damm, well im sure you can get something looking as good (if not better)
                        I suppose its a testament to how good renderign is these days that real life models and renders can be mixed up.
                        • Al HartA
                          Al Hart
                          Oops - I posted the image to my previous post before I saw that you have made a new one.
                          I'll add it here (at full size), instead.
                          http://wiki.renderplus.com/images/c/cd/Sid-plastic.jpg
                          (The jaggies around the image is because I rendered it to an alpha background, and placed it over the earth image, rather than rendering it directly on top of the earth image. Sorry...)
                          About enough for this model... I am anxious to grab something else from the 3D warehouse and try it...
                          Al Hart
                          • Al HartA
                            Al Hart
                            Maybe this would be a better image:
                            (Note: this is a photograph of a plastic model, and not a rendering of a SketchUp model 😄 )
                            http://www.keithmcneill.pwp.blueyonder.co.uk/1160862686.jpg
                            from> http://www.keithmcneill.pwp.blueyonder.co.uk/3c.html
                            Although to replicate it better, I need to set the materials to plastic rather than metal. 😄
                            Al Hart
                            • Al HartA
                              Al Hart
                              I believe it is a photograph of a plastic model 😐
                              I'll make a rendering of the SketchUp model with plastic materials and post it here.
                              Al Hart
                              • Al HartA
                                Al Hart
                                OK - I had to do one more - brightening up the image, and anti-aliasing the alpha border.
                                This is it though! 😄
                                http://wiki.renderplus.com/images/5/51/Sid5-earth.jpg
                                Al Hart
                                • Al HartA
                                  Al Hart
                                  One more note - In checking the Ratings on the 3D Warehouse, I see there is another rendering of this model:
                                  Error 404 (Not Found)!!1
                                  (picasaweb.google.com)
                                  http://lh3.google.com/Cartographer.Tom/Rz4Mo_-VZOI/AAAAAAAAAp4/jcIU5ho4dLQ/cosesat.jpg?imgmax=512
                                  Al Hart
                                  • R
                                    richcat
                                    Very nice Al, I'm really enjoying IRender nxt, and I can see you are as well. 😍
                                    Richcat
                                    • COSEDIMARCOC
                                      COSEDIMARCO
                                      Hi everybody.
                                      Thanks for using my model for rendering tests.
                                      This was the one I've done with Kerkythea.
                                      If you'd like to see more rendered models you can visit or my site, or directly my web album at Picasa
                                      All models are available in the Warehouse, except the Grendizer model, cause is still in progress.
                                      [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
