    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
    • W Offline
      wodur
      incredible, thanks.
        AlainBo
        Hello,
        I discovered and tried your tool with the last Catchup edition 15 to create the Hans Wegner chair.
        Following this tutorial, I discovered that 2 of the 3 extrusion possibilities cause problems; the J and N where the result pulled face creates unclosed faces. The problem doesnt occur when we use the V tool.
        The attachments illustrate the problem.
        Regards,
        Alain
          @Alainbo
          Tiny differences can cause issues with SketchUp/OpenGL that filter down through the API code.
          Two points can end up appearing to the 'engine' as being coincident when they are not and thereby a face is missed off. In your case it looks like a creeping tolerance issue.
          To avoid this if you scale up what you are working on [temporarily] by say x10 chances are that the extrusion vertices will all play nicely and no faces will get omitted. Scale back down afterwards and the issue won't reappear - it's the creation involving small dimensions/edges/facets etc that's the issue, but they can exist, just not be 'made' at those values.
            AlainBo
            Ok TIG, I'll try to work like that.
            • O Offline
              ossie
              Genius plugin
              Thank you very much
              • W Offline
                wtrouser
                I'm another mac user experiencing some issues with this incredible plugin, (but I'm banking on user error). I thought it might be due to running SU 7.1 on a G4 mac, but after reading the previous posts I'm not so sure. JPP works for me 1 out of 20 times. The other 19 I have to hard reboot the computer. What I've tried:
                • Verified the latest versions of plugins
                • Scaled the model up (twice)
                • Cut larger faces into much smaller segments, pulled one at a time
                • Tried while grouped/ungrouped
                • Removed all other plugins and reinstalled FredoLib and JPP only
                • Many times I let the computer sit untouched for hours, just to make sure I wasn't causing the freezes by interrupting a process
                I've attached a model of a simple curtain I'm looking to thicken by 1/16" (either direction). The model is cut into segments, and all segments would be JPP'd (verb?) out to the same thickness.
                If someone could point out the error of my ways, or take a crack at thickening it yourself, I would be indebted indeed.
                CurtainSU.skp
                  AlainBo
                  Hi wtrouser,
                  I tried to thicken your model on SU 8 Pro M2 and the last plugin and I got the same result as you.
                  Even scaling it up by 10, all push-pull tools end in an infinite loop.... 😞
                  • W Offline
                    wtrouser
                    Alainbo... thanks, that actually makes me feel better. I tried x10 and x100, and I segmented the big face into something like 15 segments. Frozen pizza. Perhaps it's too complex of a face for the plugin?
                      AlainBo
                      Perhaps. It's a pity anyway. 'J' tool could be a very powerfull feature!!!
                        Worked fine for me.
                        Scaled it up x100 first.
                        1/16" >>> 6.25"
                        JPP keeping original faces and no partitions.
                        It became unresponsive about 13% in, BUT that doesn't mean it's bust !
                        After 3mins it completed OK.
                        Scale down 0.01 to return to ~6' high...Capture.PNGthe proof...
                        • W Offline
                          wtrouser
                          TIG... fantastic! I don't suppose I could talk you into uploading your result, could I? I tried scaling up x100, and I once even let my computer go overnight. It didn't seem to matter how long I left it, I couldn't even call up the mac equivalent of the Task Manager after running JPP, the computer was so solidly frozen.
                            I didn't bother to save it...
                            I'll redo it after my dinner...
                              Here it is [v7]...
                              For some reason it stalled at 5% and took 9 mins this time πŸ˜’
                              No problem! I did have other things running this time...
                              CurtainSU.skp
                              • W Offline
                                wtrouser
                                TIG - many thanks again for the extra help! It's greatly appreciated.
                                  AlainBo
                                  You are right, I didn't tried to scale it up by 100. It was the trick.
                                  I got it in les than 2 mns.
                                    All Sketchup processes that create new edges/facets [pushpull, followme, intersect, scripted tools doing similar things], can fail if the resultant geometry is tiny.
                                    Sketchup/OpenGL cannot cope with things < ~0.1mm.
                                    There are tolerances built in to allow two points in space that are not exactly coincident to be regarded as 'equal', otherwise it'd be difficult to do many operations as calculations must always be somewhat approximated. This can mean that two very very close points might not form a line between them, as Sketchup expects two different points, the missing line then fails to split an existing face during an intersect or to complete a loop for a face, which is then missing...
                                    Using a tool like JPP on a very complex mesh with small resultant parts [like this thin curtain] might end up with some tiny bits of geometry/faces missing - it can even splat given the right errors...
                                    The trick of Scaling things up x10 or x100 etc, creating the facets etc, will avoid the tininess issues.
                                    Any Scaling of the tiny parts back down afterwards isn't an issue - very tiny things can exist, it's just their creation that causes issues.
                                    Incidentally, there can be similar issues with very very large objects too, because the enormous numerical values get ever approximated too... In that case scale down, process then scale up.
                                    Sketchup is really designed to model building and related objects.
                                    So doing complex modeling on the innards of a swiss-wristwatch [or an entire city] at 'real size' can/will cause issues at some point...
                                    • W Offline
                                      wtrouser
                                      That makes sense to me... thanks for the explanation. My issue is that I had already tried scaling the model up x100, and it still froze. Additionally, I've only had JPP work for me a small percentage of the time in the past, with models of varying sizes/complexities. It may simply be that I've got the wrong computer/SU version/plugin version combo. Until I'm willing to pony up the money for upgraded hardware/software, I really can't complain too much.
                                      [edit] This might help... after I hit 'go' on a JPP process, the computer will think for a bit, the plugin status bar at the bottom will progress left to right, and the faces I'm trying to pull will eventually appear. The cursor will change back to a pointer and all will seem well. After I then move the cursor, whether right after the process or even several hours later, the pointer will change into a spinning pinwheel and I'm frozen. It seems like my computer might be freezing after the process is done.
                                        AlainBo
                                        Hi wtrouser,
                                        I don't know if that could be caused by SU7, but on SU8, if we take care to be in requested conditions as TIG explained, it seems to work fine. Annyway, if we make the same job on the same model several times, we can see that we cannot trust the progress bar. Sometimes it freezes at different percentages. but as the process seems to ends correctly, that's not a problem.
                                        So, unfortunately, you may have to wait to upgrade to SU8 to get it working correctly. 😞.
                                        Regards,
                                        Alain
                                          srancsik
                                          Totally agree, THE MOST USEFUL PLUGIN ALL OVER!!!
                                          Thank you, thank you, thank you!!!
                                            scottbattersby
                                            Hi All
                                            I had a problem with Joint Push Pull. I solved it as I was composing this post, and decided to post the solution in case anyone else is stuck.
                                            I was trying to use Joint Push Pull to thicken a curved shell into a 3D object.
                                            In the attached screenshot you can see I have selected all the faces in the shell and invoked the Joint Push Pull.
                                            PROBLEM
                                            Only some of the selected faces are being extruded. The rest are just being ignored.
                                            Win XP Pro SP3, 32 bit machine 4.00GB RAM installed.
                                            Sketchup 8.0.16846
                                            JointPushPull v2.0b
                                            SOLUTION
                                            In plugins\JPP_Dir_20\jointpushpull_main.rb
                                            Change MAX_VISUAL_FACES = 1000
                                            to MAX_VISUAL_FACES = 10000 (or whatever is a reasonable number for your model)
                                            Hope that helps someone πŸ˜„
                                            Cheers
                                            Scott
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 16 / 19
