Coplaner faces
Is there a sure fire way to get rid of coplaner faces w/o destroying other faces.
Su is not playing nice today
I've tried intersect with model which works some of the time. What other tricks can I try to get rid of this annoying problem? -
try using the right click "smooth/soften edges" dialog box, drag the slider all the way to the left, then check "soften coplanar". is this what you are asking?
No, This is what I'm getting at...
I had to revise a part of the master plan and in doing so lost some faces i.e. the parking lot and roads. When using makefaces it closed faces but made coplanar faces in some areas. I'm finding myself tracing the thing all over again which works sometimes but not all_trial and error.
With your input, this post could be even better ๐
Register LoginAdvertisement
