    Joint Push Pull
    7 Posts 5 Posters 2.6k Views 4 Watching
    • fredo6F
      fredo6
      Here is a very first version of what I call Joint Push Pull, which is a compromise between the classic Sketchup push pull along individual face normals and the Vector Push pull whihc keeps faces contiguous. In other terms, how to extrude faces along their normal, but generate a contiguous shape.
      I guess the pictures attached are self-explanatory on what the script tries to achieve.
      The ZIP archive should be unzipped in the Plugins folder and create in the Plugins folder:
      • jointpushpull.rb, the main macro
      • LibPlaneSelectorTool.rb, to select a custom plane
      • LibVectorSelectorTool.rb, to select a custom vector
      • LibTraductor.rb, for language translation and dialog boxes. This is a new version (you must use this one, but it is compatible with the previous version published with Bezierspline)
      • LibTraductor.def, an optional configuration file allowing override of language
      • A folder JPP_Dir, which contains the 2 icons for the toolbar
        The script creates 2 menu entries in the Tools menu
        The script also implements Classic Push Pull and Vector Push pull
      There is a full doc in PDF, but it is too large to upload on this site. So I put it on the Google forum at http://groups.google.com/group/Ruby-API/browse_thread/thread/6ae80c5c688083fb.
      [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=4840:2tyretng]Link to the discussion[/url:2tyretng]
      JointPushPull.zip
      • boofredlayB
        boofredlay
        @ampa said:
        Can't believe this has no replies!
        That is because all of the replies are here.
        We try to discourage discussion in the Ruby Scripts Depository to keep it just that, a depository.
        Thanks.
        • A
          Ampa
          Can't believe this has no replies! Looks like a nice little addition to the SU toolset - gonna have a toy with it right now to see what I can come up with.
          Thank you for sharing your work πŸ˜„
          Ampa
          PS - +1 for the superb documentation!
          • N
            NORTH_FROST
            Great tool πŸ‘
            Works excellent ❗
            http://www.northfrost.se
            • fredo6F
              fredo6
              @north_frost said:
              Great tool πŸ‘
              Works excellent ❗
              Thanks.
              I suggest you try the latest version, which has more features
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6708
              • S
                sajid1999 Newcomers
                I have a problem. I purchased the joint push-pull plugin a long time ago, and every time I update or format my PC, I lose one seat. I can't use my plugin anymore, even though I'm using the same PC.
                fredo6F 1 Reply Last reply
                • fredo6F
                  fredo6 @sajid1999
                  @sajid1999
                  This is normal. If you change your PC, the unique hardware ID changes.
                  You can release old seats on this page (you'll need to sign-in)
