    Open GL Problem
    5 Posts 3 Posters 916 Views 3 Watching
      SpaceMan
      After my computer restored to factory default, my openGL does not work properly, The Google SketchUp 6 displayed like wireframe even I did not turn wireframe on. This must be graphic card problem. I am using Windows Vista Home Basic. Acer Aspire 3680-2354. Can you tell me how to fix it??
        SpaceMan
        I can not find OpenGL driver on Acer website
        • P Offline
          peterbnilsson
          do you know what video card you have, or do you have an integrated card? From looking at the Acer website, it looks like you have an integrated video card. Have you looked over this list?
          http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%203680.pdf?CFID=334435&CFTOKEN=30300403
          It has the driver links for your laptop (page 3).
          Not sure what else to try.
          • sketch3d.deS Offline
            sketch3d.de
            check the Acer website for the latest video driver, download and install.
            if it's a low end shared video solution chances are good, that the OpenGL support SU heavily relies on is neither fast nor good, i.e. you would be required to switch off the SU hardware acceleration in the SU OpenGL settings... which obviously renders SU to useless, at least for bigger models 😲
            hth,
            Norbert
              SpaceMan
              I updated Windows then the driver was updated sucessfully. It was fixed.
