    SU & ARTSTUDIO PRO
    7 Posts 3 Posters 1.1k Views 3 Watching
    • S
      seasdes
      I Came accroos some software called Artstudio Pro to modify the output from SU. Is anybody using it for work purposes?
      Web page http://www.virtualpainter5.com/tpasp1index.html
      Walter
      Using Sketchup Pro 2019
      • Mike LuceyM
        Mike Lucey
        Hi Walter,
        It looks to be new so I doubt anyone here has tried it out. I use a similar product and find that it can help sometimes.
        Mike
        • C
          canoek
          i've used the previous version of the virtual painter plug-in for ps and it works great.
          • Mike LuceyM
            Mike Lucey
            I downloaded and tried it out and binned it, results attached. The similar program that I use to better effect and with far more control is PhotoArtMaster by Fo2PIX.com. There is also a PS plug-in. Give it a try! Some info http://designer-info.com/Writing/fo2pix_photoartmaster.htm
            Mike
            • S
              seasdes
              Thanks Mike
              However Fo2Pix is now out of business. That's why I am looking for alternatives.
              Walter
              • C
                canoek
                downloaded trial ver 5 as a plugin for ps. works a little better than previous version but not sure it is worth the extra $30. don't expect this program to be a one button solution for making realistic watercolor/pencil renderings. you will still need to be proficient in ps to achieve that (ie. overlaying and manipulating different layers/opacities/hues, use of different filters, etc). i would buy it only if you are looking to expand your pool of ps filters.
                jb
                • C
                  canoek
                  well i guess it must be late. i just re-read your post and you were talking about "Artstudio Pro" not the "Virtual Painter" program. oooooops. 😄
                  i just downloaded the trial version of "Artstudio Pro" and it looks pretty good - more in line with Mike Lucy's "PhotoArtMaster" recommendation (a lot more artistic control). looks promising - i'll have to play with it more tomorrow.
                  jb
                  the big swooooosh looking thing is the program's trial version watermark
