    Plug in for CAD drawings to elevate the interior walls
    extensions
    3 Posts 3 Posters 1.6k Views 3 Watching
    • T
      thegn
      Hello out there does anyone know the plug in when you want to raise or elevate the interior walls of a building ???
      • jujuJ
        juju
        By elevate do you mean raise them up off the ground or raise them up from a zero Z plane?
        Either way, push/pull them to the required height. Remove plinth if you need to raise them off the ground, else you'll have them raised up from a zero Z plane.
        • K
          ketchup
          maybe you can use this plug in....its very cool but it just make one part of the process .
          it convert all the lines on faces, so then you have to push and pull the walls with out make the face
          http://www.iscarnet.com/sketchup/plugins/ruby/crear_caras.php
