    Select a tool with Ruby?
    4 Posts 3 Posters 704 Views 3 Watching
    • W Offline
      Whaat
      I thought there was a script that changed it so the selection tool was activated when SketchUp was started (like in SU5)
      I am wondering, is it possible to activate a SketchUp tool (not a user-defined tool) using
      a Ruby script? If so, how?
      For example, I want to activate the PushPull tool with a Ruby script.
      Thanks.
        azuby
        Have a look here.
        azuby
          RickW
          Whaat,
          The script you first mentioned is SelectAtStartup. It could be modified to select a different tool at startup, and provides a way to learn how to select tools via ruby.
          Hope that helps,
          RickW
          www.smustard.com
          • W Offline
            Whaat
            Thanks guys. That's just the info I needed.
            The Ruby support on these forums is outstanding! Keep up the good work everybody! 👍
