    Ride a Painted Pony
    11 Posts 5 Posters 1.7k Views 5 Watching
      Here's a "painted pony" in Majid's new watercolr style. πŸ˜†
      • boofredlayB Offline
        boofredlay
        Ha, cool. I have about 20 of those along with a bunch of red and gray (off brands) lining my garage. Unfortunately those horses have not been able to run for quite some time.
        That looks pretty high poly, what is the face count on that stallion?
          Wanna guess?
          File size is 139Kb. 4122 faces but 690 component instances. The clamp parts are split in half using the hidden seam method with each half being a component and the Acme threads on the shaft are instances of a little components with only three faces. The threads are separate from the central cylinder which makes adjust the length of the threaded rod a simple matter.
            boofredlay
            DANG
              DANG
              Izzat good? πŸ˜†
                Sawduster
                Man, turn a danged old cast iron pony pipe clamp into "Art". 😍 Great job, Dave.
                May all your dimensions be the sum of their total.
                Jerry
                http://www.sawdustersplace.com
                  boofredlay
                  That is some tight modeling. High poly and it looks great. Dang... yes that is good.
                  How long did it take to make?
                  Edit: Show off a Hidden line view, I would love to see some of those poly'ies. πŸ€“
                  • Darth ChocolateD Offline
                    Darth Chocolate
                    When gluing components
                    For a finish just right
                    This clamp will do nicely
                    For a joint that is tight
                    Outstanding style too
                    Have we seen it before
                    Easy on the eye
                    For your work to adore
                    Chocolate is cheaper than therapy and you don’t need an appointment.
                      Darth, that's very good. Thank you.
                      Boo, here's the hidden line view. I guess I could probably afford to add a few faces on the end of the crank. As far as working time, I suppose I have an hour or an hour and a half in it. It didn't really take too long. I had a real example of the clamp at my desk to work from. Actually took measurements as I went, too. Most of the parts were easier to draw whole and then split in half.
                        dylan
                        Dave that looks pretty cool in hidden line form, it really shows some modelling skills to produce so quickly and to such small model size.
                        Very nice work.
                        Any chance, if you get time of a small tut showing your methods in creating one or two components?
                        http://dmdarchitecture.co.uk/
                          Very nice work.
                          Thank you Dylan. Let me see if I can come up with a tutorial showing how I did part of the clamp. The cast parts are all done using the same basic method. I'll see if I can show my work. πŸ˜‰
