    How to make a waterfall?
    43 Posts 16 Posters 15.4k Views 16 Watching
    • EdsonE Offline
      Edson
      i need a better way of doing a waterfall in SUp than just coloring a plane.
      the picture shows the situation: a large sheet of water falls from a top pool into a lower pool.
      any ideas on how to do it? the model will be exported to be rendered in another app, but i would wish it look believable in SUp.
      http://www.mahfuz.arq.br
        Especially if rendered, I'd place a little curvy face (curved at the top as the water starts falling) in front of that wall so that when it is rendered (with hopefully a better texture), it can be partly transparent and the wall visible behind it.
          remus
          something like this?
          i'll do you a quick tut if its the sort of thing your looking for.
          • EdsonE Offline
            Edson
            it definitely is. i would appreciate it if you could do that. thanks.
            • jujuJ Offline
              juju
              How about creating two squiggly lines (top and bottom of waterfall) and using the skin ruby on it?
                remus
                here you go, feel free to ask questions as its a bit rough around the edges, as tuts go.
                edit: the tut basically does what juju's describing.
                waterfall tut.skp
                  alpro
                  Edson, here's a quick idea. skp attached so you can play around till you get the effect you want. Sorry couldn't attach skp as it was 577 KB zipped. If you're still interested I can e-mail it to you but it seems like remus did a nice job.
                  Mike
                  • Joe WoodJ Offline
                    Joe Wood
                    Maybe this might help Edson? Alan Fraser made this falling water for my tsukabai. Check out how he did the splashes πŸ™‚ with a little tree.
                    Tsukabai.skp
                    Joe Wood
                    woodsshop.com/
                      alpro
                      Just had a look at your tut remus, very good info. I rarely use any rubies. What I did was very simple, draw a sqiggly line, copy it and close the ends in to form a face, draw another line for the water path, use the follow me tool. That's what I love about SU, so many ways to accomplish something.
                      Mike
                      • EdsonE Offline
                        Edson
                        thanks all for the information and for taking your time to help me. as soon as the compettiton is over i shall post the results i obtained with your help.
                        regards.
                        p.s.: the kids who work for me are amazed at the generosity and resorcefulness of the members of SCF. no questions go unanswered here!
                          tomsdesk
                          Edson, this is fun: my answer was to set the water texture to "projected" then exturd the face (I also selected some to the resulting vertical faces and set them to not cast shadows). With a splash image (I just saw a link to a couple of free ones here a couple of days ago but can't find it now) at the bottom and some work at the top (like Mike's...could you please post that on Kelley's site for me, thanks a bunch), then some scale squeezing like real water...would look pretty good?
                          waterfall.skp
                          2.5D Trees & Shrubs!
                            tomsdesk
                            BTW Mike...how'd you do that?
                            • EdsonE Offline
                              Edson
                              thanks, tom. very good. another sound way to go about it.
                              we are actually putting all the ideas together to create our own water.
                              by the way, did you forget about those poplars i teased you to do?
                              • 3 Offline
                                3eighty
                                Over in the 3d world, we make waterfalls out of terrains turned sideways and then a texture added...If you would go get the free copy of Bryce 5.5 (DAZ), you could make great falls and import into Sketchup...
                                  alpro
                                  Still playing around. See what you started Edson?, now I have to add some patio stones, some greenery, maybe some outdoor furniture.
                                  @ Tom, I explained it a few posts above yours, wanted to post a skp but file was to big. Will post some screen grabs, it's pretty simple though.
                                  Mike
                                  • FrederikF Offline
                                    Frederik
                                    It looks really great, Mike... πŸ˜‰
                                    What program did you use for the renders..??
                                    And - can I ask you to send the 'skippy' to me by mail..?? frederik [at] kerkythea.net..?? πŸ˜‰
                                    Cheers
                                    Kim Frederik
                                      alpro
                                      3eighty could you post a link for the free Bryce 5.5, I couldn't find it on the DAZ site. TIA
                                      Mike
                                      • EdsonE Offline
                                        Edson
                                        yes, mike, quite a nice response. i have sent you a PM with my email so that you can send me the skippy when you are done.
                                        cheers.
                                          alpro
                                          Thanks Frederick, I used Podium. BTW, I'm looking forward to the KT release, haven't really used KT much because I was such a rendering newbie but the new release looks awesome. Will mail you the skp, can't believe this has generated such interest as it seems pretty easy.
                                          Mike
                                            tomsdesk
                                            Edson, no didn't forget...though I do try too (I started a really complicated rendition and figured out how to make them reasonable size-wise, about a meg, and close-up good looking, but now remains the tedium of work to complete :`) I'll get there, and hopefully they'll be worth the wait.
                                            Mike, no limit on Kelly's server...but if you'd rather, and have the time, please email to me too: tomsdrop (at) swbell (dot) net
                                            • 1 / 3
