    Steam Engine- Working Model in SketchyPhysics
    4 Posts 3 Posters 1.0k Views 3 Watching
    • J
      Jackson
      Just a few pics of this working model of a steam engine I did using SketchyPhysics- the model is posted in the SketchyPhysics subforum.
      http://www.sketchucation.com/scf/viewtopic.php?f=129&t=3115
      As I explain there, it's not finished and probably never will be, but I thought I may as well post it for others to play with.
      Jackson
      • V
        vanni31
        Wow !!!!this is very cool :thup: :thup:
        These are the objects that I like πŸ’š
        thank you
        • boofredlayB
          boofredlay
          Nice Jackson.
          Did you purposefully blurr the image in certain areas to make it look as though it was a photograph focused in the center? Nice effect.
          • J
            Jackson
            Thanks Eric,
            The best thing about it (if I may say so πŸ’š 😳 ) is setting it going using the SketchyPhysics plugin- it's great fun watching it slowly start moving before getting up to full speed.
            The blur is done using Lewis' brilliant SU Fog/Styles trick to create a depth map from SU and then copying that to the alpha channel in PhotoshopCS3 and applying the "Lens Blur" filter to select the focal distance and depth of field.
            http://www.sketchucation.com/scf/viewtopic.php?f=71&t=1156&st=0&sk=t&sd=a&hilit=depth+depth+map
            Jackson
