    Steam Engine- Working Model in SketchyPhysics
    4 Posts 3 Posters 962 Views 3 Watching
      Jackson
      Just a few pics of this working model of a steam engine I did using SketchyPhysics- the model is posted in the SketchyPhysics subforum.
      410 Gone
      (www.sketchucation.com)
      As I explain there, it's not finished and probably never will be, but I thought I may as well post it for others to play with.
      Jackson
      • V Offline
        vanni31
        Wow !!!!this is very cool :thup: :thup:
        These are the objects that I like πŸ’š
        thank you
        • boofredlayB Offline
          boofredlay
          Nice Jackson.
          Did you purposefully blurr the image in certain areas to make it look as though it was a photograph focused in the center? Nice effect.
            Jackson
            Thanks Eric,
            The best thing about it (if I may say so πŸ’š 😳 ) is setting it going using the SketchyPhysics plugin- it's great fun watching it slowly start moving before getting up to full speed.
            The blur is done using Lewis' brilliant SU Fog/Styles trick to create a depth map from SU and then copying that to the alpha channel in PhotoshopCS3 and applying the "Lens Blur" filter to select the focal distance and depth of field.
            410 Gone
            Jackson
