    Line Weights?
    layout
    5 Posts 3 Posters 8.3k Views 3 Watching
    • K Offline
      Klog
      Has anyone found the solution to controlling ling weights?? That is, more than is in the styles tray.??
      Thanks, Klog
      Klog http://www.tetontimberframe.com
      Win 7 Pro Dell Precision M4500 4Gig 4 threads @ 2.9 GB/S
      Skp 7 Pro & 8
        You mean the line weights of the SU model (insert) in LO or the native LO lines?
          dylan
          Thanks, Klog
          Two lineweight settings available in LO, depending on what you are doing are as follows:
          Shape Style/Lineweight/0.5 - 40
          SketchUp Model/Styles/adjust lineweight in bottom right corner.
          http://dmdarchitecture.co.uk/
          • K Offline
            Klog
            Gaieus/Dylan
            Thanks. By line weights I mean on the printouts and possibly by layer so that cabinetry and other less important features of a floor plan are more background. I've seen the "depth" button on the edit>edges menue. It helps. Justlooking, like many , for a little more discrimination of line thickness. And Dylan, I will check out tyhe item you posted.
            Thanks again
            Klog
            Skp 7 Pro & 8
              Klog, currently neither in SU (therefore) nor in LO different lineweights for different elements (layers, groups etc) are possible. The reason is that LO only imports what you can see in SU (and allows limited manipulation) but there's no other interactivity between the 2 programs (as far as I understand it mechanism).
