    First question - change exterior wall thickness
    3 Posts 3 Posters 653 Views 3 Watching
      afigure
      Looking down on my model: I am trying to figure out how to change exterior wall thickness all the way around. I have already put a few windows in, hoping that won't change anything. Thanks.
      • AnssiA Offline
        Anssi
        There is no workaround that I know of, but a component that is "hole-cutting" or otherwise glued to the surface, will follow if you use the push-pull tool on the surface.
        Anssi
          dylan
          Remember that when you use PushPull to pull or push the wall to the new required width, simply double clicking the PP tool on other surfaces after will give you the same wall width again.
          It will speed things up a lot for something like this.
          http://dmdarchitecture.co.uk/
