    Push-pull?
    15 Posts 7 Posters 1.8k Views 7 Watching
    • P
      princess
      Hi Gaieus
      Thanks for the tip. However;
      The window does not work but the door does. This is consistent whatever I do. All faces are parallel.
      Thanks again,
      Molly
      I've also altered my preferences to alert me when someone posts a reply but this is not working. Any ideas?
      If one plants poison ivy, one does not get to pick strawberries.
      • GaieusG
        Hi Molly,
        A simple skp file would be good to have a look at. Sometimes there are small inaccuracies in SU that are not very apparent (even the axes show right) but can cause problems.
        If you set your preferences to notify you upon a reply, it won't - until you "subscribe" a topic. Have a look at the very bottom left of this page you are reding at the moment and see the subscription link.
        Note that the email will go out under the admin's email address (i.e. gaieus<at>sketchucation.com) so you may wish to add this address to your approved addresses list (or whatever your email system/client calls it).
        • P
          Pagan
          Hi there,try this...
          http://www.speedyshare.com/129974256.html
          Small video demonstration of two way's using push-poll...
          • P
            princess
            Hi Pagan
            Thanks but my computer cannot download this film, despite my adding plugins. Is it on YouTube by any chance?
            Molly
            • G
              GreyHead
              Here's a flash version of Pagan's tutorial:
              [flash=640,498:2buh0qp4]http://greyhead.net/files/su/push-pull/push-pull.swf[/flash:2buh0qp4]
              • P
                princess
                Thank you but can someone explain why the second opening took more work? Why did it not work as easily as the first one?
                Molly
                  Why don't post your file here?
                  with the 2 states before and after
                  So people who have a Mac can make test 😉
                  • P
                    princess
                    Thank you GreyHead. All is explained! Works fine now. This shows how important it is to observe the clues from the inference engine.
                    Molly
                    • G
                      GreyHead
                      Because in the first one he stopped the push-pull when the SketchUp inference told him that he was exactly aligned with the back face. See the little blue square, the tool-tip and the dotted line here - all are clues - but they come and go quickly if you move too fast.
                      Bob
                      • Alan FraserA
                        Alan Fraser
                        Another thing to take note of is the fact that the P/P tool remembers how far it went last time. This means that if you have a number of holes to punch through a wall, you only need to get the first one correct....all the others can be done automatically; simply by double-clicking on them with the P/P tool.
                        It's also a useful trick when pulling up surfaces that have a regular height difference...like steps.
                        3D Figures
