π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Creating objects automatically
Hi everybody,
I would like to create e.g. cubes automatically. The parameters how many cubes, the distances of these cubes to each other and the dimensions of these cubes (all cubes will have the same size) are calculated with MS Excel.
I want to create a SketchUp file or a drawing with these parameters automatically.Is it possible? How?
Thank you in advance
Andreas
Create your cube and use the "Grow" ruby script by Tig
Save on your computer as Grow.rb and place it inside the folder plugins -
Thank you. That works fantastic.
Now is it possible not to create the cubes not manually but with another plugin? -
Look here all is named "box....rb"
Thank you.
I will work on it...
