    Setting up a scale of 1:20
    14 Posts 8 Posters 7.2k Views 8 Watching
    • Jean LemireJ Offline
      Jean Lemire
      Hi folks.
      If you want to print a 8 cm line as 8 cm on paper, you use a 1:1 scale.
      If you want a 1:20 printing scale, your real life 8 cm lines will prints as 4 mm on paper.
      Draw the line in real size (8 cm).
      Select any of the standard view.
      Disable perspective.
      Now, in the Print Dialog box, you will be able to specify the scale used for printing. For example that 1 cm in model is 1 cm on paper (1:1 scale) or 20 cm in model is 1 cm on paper (1:20 scale) etc.
      As for scaling when drawing, it may be required when modeling very small objects. For that I simply set my units to meters and pretend that they are millimeters. For exaple, I need to draw a line of 2 mm. I enter 2 in the VCB. SU will interpret this as 2 meters (2000 mm). After my model is completed, I simply scale the model down with the Scale Tool by a factor of 0.001. Since SU will not accept this number, I do it in two steps using 0.1 then 0.01 or the reverse.
      Read the help about printing, more specially, the Printing to Scale chapter.
      Just ideas.
      • F Offline
        franznad
        Jean Lemere
        As I am new to Sketchup, could you please elaborate on your instructions regarding drawing an 8cms line.
        You say draw the line in real size 8cms. By that do you mean measuring 8cms on the screen?
        Disable perspective, not sure how you do that.
        All boxes in Print Preview and Print are greyed out in my Print Dialog Box. How do you get them working?
        You suggest reading information in Help on 'printing' and 'printing to scale'. I checked in the ON Line Search and nothing came up under these two titles. I've also checcked the pdf document on Sketchup and the tutorials but can't seem to find anything relevant to sort this print problem out.
        franznad
          remus
          I cna help you with a few points, but i dont know a lot about printing, sorry.
          1)when jean says draw an 8cm line, he measn 8cm in SU. To do this youd click the start point for the line, get it going in the right direction and then type 8cm (or the equivalent unit) into the VCB.
          2)to disble persepective, go camera->parallel projection.
          1. http://sketchup.google.com/gsu5vtviewer.html#id=13 thats the link to the SU video tutorial on printing.
          good luck!
            CWatters
            Turorial here...
            http://www.liv.ac.uk/abe/students/sketchup/05b_output.shtml
            I found this works fine for printing something like elevations of a building at 50:1 but had problems printing a drawing of a 1 inch square at 1:1.
            • F Offline
              franznad
              Remus
              I am sorry I can't seem to get your instructions. I start to draw the line and a figure appears in the VCB say 350cms. I stop, clear the VCB and enter 8cms. I am not sure what this acheiving, because if I use the tape measure to measure it, it is 350cms.
              franznad
                remus
                ok, heres the exact sequence of mouse clicks and key presses, this should work ❗
                1)Clcik to set start point
                2)get the line going in the right direction
                3)type in '8' cm
                4)press enter
                  Franznad,
                  You shouldn't click into the VCB and clear anything - just type. If your VCB is showing 350cm when you start drawing, you are zoomed out quite a lot for a 8 cm long line and when you hit Enter, you may see almost nothing buut if you zoom in, you will see your tiny line.
                    CWatters
                    What Remus said...
                    To draw a rectangle 8 foot by 6 foot..
                    1)Click where you want a corner.
                    2)Move pointer to roughly the right direction as if drawing normally but do not click mouse.
                    3)Type "6',8'" (without double quotes) and press enter
                    4)Rectangle will be completed.
                    No need for other mouse clicks. No need to click in the VCB as typing 6',8' will automatically overtype whatever is in there. Note you can mix your units. For example you can type 6.5' to "mean six and a half feet" or you can type 6'6". If you are working in metric it does the conversion for you as well.
                    • F Offline
                      franznad
                      @cwatters said:
                      Turorial here...
                      boxes
                      CWatters
                      I don't seem to be having much luck with Sketchup. All the boxes in PRINT PREVIEW are greyed out apart from PRINTER NAME and PRINT QUALITY. I have checked out all relevant tutorials on printing but can't see what I am doing wrong. Perhaps I should invest in a book on Sketchup. How about 3D Construction Modeling by Dennis Fukai. It's based on
                      Sketchup 4. How relvant would it be to me using SU 6. The other books on SU seem to be hugely expensive.
                      Franznad
                        pmiller
                        SketchUp for Dummies by Aidan Chopra is only $16.99 on Amazon. Start with that.
                          Kenny
                          To avoid the boxes being greyed out ensure you have on one of the pre-defined views obtained with the little 'house' icons at the top of the page. You would use the top view for a plan view for example. Secondly on the menu along the top ensure you click 'camera'then 'parallel projection'. You can't print to scale in perspective. It should work for you now.
                          Kenny
                          http://www.townscapesolutions.co.uk/
