    Problem with 3dtext
    8 Posts 4 Posters 1.0k Views 4 Watching
      Dave Irvin
      Hi All,
      I'm having trouble with the 3dtext command. When I select the command either from the menu or the toolbar I get no response and no text dialog box. SU freezes up until I hit the escape key. It's almost as if the dialog box is waiting for my response but it is not visible. I reinstalled/repaired SU pro to no avial.
      It used to work before I upgrade to pro.
      Any ideas. I want it back.
      Dave Irvin
      I'm using XP, 2g ram.
        RonanR
        Hi Dave,
        I don't have the same problem as you, but I have noticed that my machine 'thinks' a while before showing me the 3D text dialog box... so something is happening in the background. Never lasts more than 5 seconds though, which still seems a long time.
        %(#BF00FF)[Please keep signatures minimal.
        Oh, and ditch incandescent light bulbs.]
          Dave Irvin
          Thanks Ronan,
          Nope. I just tried being patient and no cigar. I finally hit escape to get my cursor back after 2 min. I did see the 3d text dialog box flash onscreen for a split second, then disappear.
            Dave,
            Try to check whether the dilogue is "hidden behind" the main SU window. If you exit from full screen mode, you can drag the main window aside and see what's under it. Sometimes these dialogues get lost from the main window. If you happen to find it, drag it inside the main window and it'll be fine.
              Dave Irvin
              Thanks Gaieus,
              Good thought but I tried it and no luck. It used to work, so I pulled up the old file where I used 3d text and still couldn't get it to work. Very puzzeling.
              • TaffGochT Offline
                TaffGoch
                Dave,
                I don't know when the 3Dtext routine reads the fonts on the computer, but if it does so at the onset of the tool, a problem with your fonts could be glitching SketchUp.
                I'm not saying this is the cause, but it could be one potential item to check off your debugging list. Since SketchUp has had problems with certain characters in the filenames of textures, perhaps font filenames could also present similar problems.
                Side note: I have many (probably too many) fonts on my machine, but haven't seen this behavior. So, I don't think the number of fonts would be a problem; maybe just one font filename is confusing SketchUp.
                Just thinking outside the box here...
                Regards,
                Taff
                "Information is not knowledge." -- Albert Einstein
                  Dave Irvin
                  Hmmmm, Interesting idea, I'll check it out. Thanks
                    Dave Irvin
                    Well, I couldn't find any text files with odd looking names so I uninstalled the whole shootin match and reinstalled and now it works. Must have been a corrupt file somewhere.
                    Thanks for the ideas.
