    [Plugin] Auto Centerpoint
    41 Posts 13 Posters 35.4k Views 13 Watching
    • W Offline
      watkins
      Dear John
      If you go to:
      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm
      you will find two scripts. One deletes construction lines only, and the other construction points only.
      Regards,
      Bob
        Baker518
        I find myself often deleting the guides and lines, only to replace them at a later time. I think rather than delete them, just make them go to a layer of their own instead. That notion has just dawned on me, remembering that I had asked for the same delete options only to find it already existed in the two scripts mentioned.
        Another thought comes to mind, TIG has written a new script that moves hidden to layer, this may be something to expand on for the guides, but I dont know.
        @tig said:
        See: http://www.sketchucation.com/forums/scf/viewtopic.php?p=47582#p47582 for v1.1...
        This script Hidden2Layer.rb moves hidden active entities onto a layer called HIDN...
        Usage: Put this file into the Plugins Folder.
        Pick "Hidden to Layer" off Plugins Menu...
        Any Hidden Active Entities are moved onto Layer HIDN
        This means that any Hidden Model-based Geometry is moved,
        BUT if you want to do Hidden Entities that are inside of
        Groups or Component Definitions then you need to Edit them
        so their Entities are then 'Active' and then on running
        this tool they will be moved to HIDN...
        It's main use is that when you want to export to DWG or DXF for use in CAD packags the SUp based hidden geometry is on a special layer - HIDN - and can be frozen or switched-off so it's not visible...
        Don't worry about things you have no control over. Worry is a lack of Faith!
          Jim
          It's trivial for me to put the construction points on their own layer. What if I used CenterPoints as the layer name?
          Or would you want to select a layer each time the extension is enabled?
            Jim
            @baker518 said:
            Jim,
            I don't care what anyone else says, I like it. It seems like you wanted to do more but ran out of gas.
            Thanks Mike, it does exactly what I meant it to do - no more, no less 😄 I didn't write it for anyone in particular but myself, however i did expect a few more comments.
            Here's what I hope you ultimately wanted to do with this:
            The guide can easily be deleted, simply by clicking "Delete Guides".
            It only shows up on the original single surface, it doesn't expand as an object is Push/Pulled, and it doesn't set a guide at the end of say, a cylinder when p/p, nor does it connect the two guides as a center line would. If you were ever to consider modifying it, this is something I would like to see.
            Regardless, I will still use it, thank you very much
            Mike
            These are good ideas. I think I can make it add another point after a pushpull on a cylinder.
            • JClementsJ Offline
              JClements
              Jim, this functionality has been on my wishlist as a "standard" for the circle tool for the last two releases of SU.
              Since the script is loaded as an extension, perhaps you could allow holding the Alt-key on the first click to disable the centerpoint or vice versa (allow the centerpoint to be created only with the Alt-key)?
              I do wish there was an option to automatically assign the construction point to a specified layer so that I can easily turn all my "construction" geometry on or off. Better yet, but I don't think its possible, is to have the extension change the way View > Guides and Edit > Delete Guides operates in the first place. My ideal would be
              View Guides:
              ·Guides
              ·Construction Points
              ·Both
              Delete Guides:
              ·Guides
              ·Construciton Points
              ·Both
              At any rate, a big thank you.
              QUESTION: what does the Singleton.rb in the Ruby subdirectory accomplish?
                JClements
                Jim, something like "CircleCenterPoints" as a layer name is fine by me. If I want to rename the layer or move the points to another layer later on that is easy enough to do; at least this way the points can be turned on or off irregardless if they are in nested entities or not.
                  Baker518
                  Jim
                  You write good scripts, good thought and insight to need and purpose. I am confident that what ever addition and/or change you make will be good. As far as a layer, for guides and/or points, I like it the layer name CenterPoints, that way any center point you add should end up there, maybe.
                  Mike
                    Jim
                    Points now get put on CenterPoints layer
                    Plugin: Auto CenterPoint
                    Auto Centerpoint automatically adds a centerpoint to circles, arcs, and polygons. Update Sep 2011 - This is an older plugin and not well...
                    (sketchuptips.blogspot.com)
                      JClements
                      Jim, are you sure the link downloads the latest version?
                        Jim
                        Yes, just copy the new files over top of the ones already installed.
                          Jim
                          @jclements said:
                          Jim,
                          This may be a bug.
                          When finishing a circle with the second mouse click, I can't make an entry the VCB to change the radius.
                          John
                          Seems you're right. Let em look into it.
                            JClements
                            Jim,
                            This may be a bug.
                            When finishing a circle with the second mouse click, I can't make an entry in the VCB to change the radius.
                            John
                            • Y Offline
                              Yup_done
                              After a brief time away from sketchup, I've decided to give it another shot.
                              Your plugin seems "spot on" and dare I say: something which would be better off included in the actual program itself.
                              Kudos and regards,
                              Chris D, near MTL, canada
                                Jim
                                Thanks Chris,
                                I haven't yet had time to see if I can fix the VCB problem. I had a couple projects come up unexpectedly.
                                  Jim
                                  New version is available here:
                                  Let me know how it works for you.
                                  • jujuJ Offline
                                    juju
                                    Error Loading File auto_centerpoint.rb
                                    No such file to load -- ruby/singleton
                                      Jim
                                      OK, should be fixed. You'll need to download again from the same link and try again. Sorry.
                                      • O Offline
                                        outersketcher
                                        Jim,
                                        As a newbie at sketchup, I was excited to find this ruby script.
                                        The script seems to have installed ok since I do get the little single button menu.
                                        But, how do I use it? I've tried clicking on it first to activate the ruby... but when I use the circle tool... I don't see any center point. And I've tried creating the circle first, and then clicking on the auto center button and then back to the circle again... neither method works. Am I not doing something right?
                                        I am running sketchup 6 on an intel-based mac running system 10.5.2.
                                        Thanks,
                                        outersketcher
                                        "I mostly enjoy not being dead.." -Grandpa
                                          Jim
                                          I just downloaded it and reinstalled it, and it works. You should have the following files and folders in your Plugins folder:acp.jpg
                                          Then, you can toggle the creation using the toolbar button.
                                          One other thing - points aren't created until you switch tools.
                                          • O Offline
                                            outersketcher
                                            Well, bummer...still can't get it to work yet.
                                            I've double checked the plugins folder and the two folders and file are there.
                                            The plugin button appears and responds to my mouse by going darker when I click on it... but, nothing else happens when I draw the shape and click to a different tool.
                                            This might be a Mac thing? Are there any other Mac users using this ruby okay?
                                            David
                                            • 1 / 3
