    Error loading file
    7 Posts 2 Posters 957 Views 2 Watching
      confitex architure
      Hello,
      When I try to launch a newly written script, at sketchup startup, I get the following message that means Error loading file...
      ^Erreur de chargement du fichier insertc.rb
      C:/Program Files/Google/Google SketchUp 6/Plugins/insertc.rb:210: syntax error name = "insertc.rb"
      I see no reason it happens because I've launched it once and at the second launch, it failed.
      Please, I need your help
      Thank you.
        Hello,
        Thank you.
        What does line 210 of the script say ?
        Perhaps give a few lines either side too - you don't need to give away the whole script if you don't want to...
          confitex architure
          Hi TIG
          thanks, you're right it would be easier...
          end		#### END OF CLASS ####
             name = "insertc.rb" #this one is line 210
             unless file_loaded?(name)
                menu = UI.menu("Plugins")
                menu.add_item("insertc") { Sketchup.active_model.select_tool InCompo.new }
                file_loaded(name)
          I also have these alerts...
          C:/Program Files/Google/Google SketchUp 6/Plugins/insertc.rb:212: syntax error
          C:/Program Files/Google/Google SketchUp 6/Plugins/insertc.rb:213: syntax error
          C:/Program Files/Google/Google SketchUp 6/Plugins/insertc.rb:213: unterminated string meets end of file
            ### Try changing 'name' to something else in case it's clashing with a 'name' variable somewhere else...
               name_of_plugin = "insertc.rb" #this one is line 210
               unless file_loaded?(name_of_plugin)
               file_loaded(name_of_plugin)### Move this outside of 'unless' test...
              confitex architure
              still got that
              I'm editing my script in notepad++
              I don't see any reason why that happens
                confitex architure
                There were something wrong with a previous UI.messagebox, mabey a quote problem, I don't realy realize...
                	UI.messagebox "Added Bed"
                end #if
                end #Place_Component
                thanks TIG !!
                  Although the SUp Ruby API doesn't stress it, I think it's safer to put things into () after a method:
                  So UI.messagebox "A message..." becomes UI.messagebox("A message..."), you are then more likely to spot errors like missing quote closing.
                  If you are using Notepad++ (I do too) then set up your Ruby format defaults to say have any strings in red - then if you miss off a closing " everything afterwards is coloured red and stands out as wrong...
