    Quad core: slow
    35 Posts 10 Posters 5.7k Views 10 Watching
      remus
      Jeff, you can set process' to run on different cores, so if you had a qud core machine and three different SU window open, you could set one instance of SU to run on one core, and then another on a different core, etc.
      EDIT: this is in vista btw, not sure what the case is with os x.
        toxicvoxel
        How many of those offering advice here actually uses a quadcore with a descent graphics card set up to optimise running SU? If not your theoretical input could be misleading to those looking for real information on which to base purchases or system setup.
        • jeff hammondJ Offline
          not sure what you're going to say is a decent card is but i use a geforce 8800gt with an intel mac 2.66 quad.. 5g ram...
          truth is, i don't notice much of a sketchup performance boost with my desktop over my laptop (g4 powerbook... 1.33 PPC chip.. 1.5g ram..)... it's just that on the laptop, i pretty much have to close all apps except sketchup to get it to run good so in the case of multitasking, multi cores are a no brainer.. (in contrast, i do a lot of image toning/management/editing with ~80mb files and there are incredibly noticeable performance differences between the two machines while using apps such as photoshop...)
          .. most sketchup operations aren't very demanding and i only notice major enhancements with the faster chip for certain things -- complex follow me deals, soap skin bubble, joint push pull, copy/move etc.. those are the instances where i wish for multicore support because i do a lot of complex curve type of drawings which i think i could simply coast through if i weren't relying on one core..
          strictly speaking sketchup however, a quad is going to offer little to no performance enhancement.. to say otherwise is misleading.. my quad can deal with higher entity drawings better than the laptop but that's due to the better card.. still, that difference isn't highly noticeable and once i get to around 25,000 pieces, the quad will start to glitch.. the problem is in the programing and you can't just throw money at it to deal with it.. instead of doing the my machine is bigger than yours argument and discussing minimal gains after a couple thousands of dollars worth of upgrades - it would make more sense to get the programming right first...
            toxicvoxel
            Jeff, your argument obviously does not support multi-threading...
            Did anyone say that SU would be faster on Quad - all other things being equal?
            What I did suggest is that the performance loss is propbably due to an inferior graphics card rather than the MC processor. This is supported by the response by Pazu to the question on the Google forums.
            http://groups.google.com/group/Sketchup-Pro/browse_frm/thread/e1a7e5c20e16c98e/6c661597f33b7c47#6c661597f33b7c47
            I suggest to you that waiting for HQ to rewrite the SU code rather than spending money on a good graphics card may not be realistic advice to the initial inquiry.
              seriously, how much of the problem is going to be solved by buying a thousand dollar video card?... i'm assuming the OP is working on fairly large drawings (garden design - plants/leaves/etc) without too much organization.. the best (and cheapest) solution would be to start using groups and components which can be hidden or replaced with low poly versions while doing the bulk of the project..
              • AnssiA Offline
                Anssi
                The few "official" responses from the SU team to queries like this have always stressed that SU performance is more dependent on the CPU than on the graphics card, and that a "decent"(whatever is meant with it) card is enough. They also have said that the workload is divided between the CPU and GPU so that the CPU takes care of the geometry while textures and shadows are generated by the GPU.
                My models are small, and I generally don't use tons of textures. My oldest computer is a 2.66 GHz P4 with a 64 Mb old ATI All-in-wonder card, and it runs SU 6 quite OK. At work I have a 3.6 GHz P4 with a Quadro FX 1400 card. Looking at the specs, it should run circles around the other, but in practice it is, well, just noticeably faster, as an user experience, the performance boost is even smaller than the difference in CPU clock speed.
                Of course my next computer will be a multicore, but I just don't see a pressing need to upgrade just yet.
                Anssi
                  toxicvoxel
                  Well the guy has already 'upgraded' to quadcore and is looking for a way to achieve performance comparable to his older machine - to which I have made my recommendation for a better graphics card based on my actual experience - which has been confirmed by a specialist on the Google forum that the specific card he uses is creating the bottleneck.
                  If the bloke has to go on the advice given by some here he should do one or a combination of the following:
                  1.Don't upgrade to multicore for the time being(Too late!)
                  2.Find a largely redundant & outdated single core Pentium 3GH+ instead and work with a single window session at a time. (!)
                  3. Wait for sketchup to support multithreading before spending any more money on a graphics card.(Yeah right!)
                  4. Work with smaller and better organised models than before.(Not always possible.)
                  In context with his question is this the most helpful response that this forum can offer?
                    and..
                    5.. go spend a $1000+ on a graphics card so you'll be able to rotate your model more cleanly while shadows are turned on..
                    the only real solution here is to work in a more organized fashion... everything else in the thread simply states that what he is experiencing is normal and should be expected.. (well, at least what i think he's experiencing... he hasn't replied or gone into detail about what exactly he's experiencing)
                      toxicvoxel
                      I guess that answers my question.
                      • AnssiA Offline
                        Anssi
                        There has often been talk about the need for a SU benchmark. That would probably stop us from arguing.
                        About the video card issue: If it is reasonably current, and SU can be made to run with Hardware Acceleration on, I am rather convinced that changing it is not money well spent.
                        I have seen posts in these forums where people who have upgraded from a mediocre Geforce card to an ultracool whizbang QuadroFX complain about zero performance gain. (Yes, agreed, when speccing for a new machine for pro SU use you should go QuadroFX if you can afford it)
                        Anssi
                          toxicvoxel
                          Well Anssi, I actually use this combination of hardware, so I'm not speculating on this or giving second hand advice. I can only reiterate that in my experience a top-end card in conjunction with MC has speeded up my workflow significantly. - But then maybe this is my imagination...
                          PS: If you do a search you will find that I actually suggested that a benchmark be developed as a SCF community project, but it was pooh-poohed by the other ruby programmers. Maybe I will just have to write one myself if it means that we can eliminate speculative advice about machine performance.
                            s_arrow
                            First of all, thank very much for all of the answers and advices. I have two videos and a "sku" file uploaded if anyone can see if the composition is too complex:
                            Videos are:
                            http://www.youtube.com/watch?v=cYFyHbNtHls
                            http://www.youtube.com/watch?v=6bsdNHqQ06Y
                            (sorry for the quality, but you can see clearly that the lines takes too long to show up after mouse clicking).
                            The "sku" file is uploaded at:
                            http://rapidshare.com/files/99299925/sketchuptest.rar
                            I'm really happy for all of your help.
                            Greets.
                              wow.. that is the biggest skp i've ever opened and it definitely slows my system to a crawl.. there's well over a million edges and faces + tons of materials, images, etc.. sketchup simply isn't designed for this type of abuse..
                              --model info for those that haven't downloaded the file...
                              15.5 MB
                              Edges 857746
                              Faces 318839
                              Component Instances 137582
                              Guide Points 30
                              Groups 2659
                              Images 12
                              Component Definitions 108
                              Layers 121
                              Materials 171
                              Styles 1
                              looking forward to hearing how toxic's system deals with this thing..
                                remus
                                Thats a pretty weighty test file, surprisingly my system just about handled it, there was a second or two delay when orbiting, and i didnt dare to turn on shadows or xray, but you could work with the model if you needed to.
                                  yeah, i guess if you have tons of patience it would be workable but seriously, i couldn't handle it.. i can rotate it ok, draw lines decently, etc.. the problem starts showing itself once you try drawing some stuff..
                                  ex - it takes me 6 seconds to draw a sphere in a blank window.. with this drawing, it took me 27 seconds.. going off of that, it would take a full days work to draw something that would take 2hrs.. i'll pass.. (and i didn't have to rotate the model in order to draw the sphere - doing that would take even longer)
                                  i would seriously look into some renderers to deal with all these plants instead of trying to draw them all in sketchup.. plus, the final output will look way better anyway..
                                    remus
                                    Yeah, im sure it would be a far better idea to use something like those proxies kwist was experimenting with. Or even just add the components in the renderer.
                                    • sketch3d.deS Offline
                                      sketch3d.de
                                      @anssi said:
                                      ... upgraded from a mediocre Geforce card to an ultracool whizbang QuadroFX complain about zero performance gain.
                                      sure, comparing speed of a GeForce w/ an Quadro FX in the same price range will show a better performance for the GF. The advantage of the Quadros is the quailty of the driver especially if a full and stable OpenGL support is required.
                                      anyway, SU is currently CPU driven sothat the fastest dual core CPU is probably the best choice for a performance optimized system and probably the best bang-for-the-buck compared w/ quad core systems.
                                      iirc for getting the user the impression that a system double its speed the system performance needs to be roughly quadrupled 😲
                                      rewriting SU for a multi-threading of modeling operations is probably a difficult task compared with slicing a render output in mutiple chunks, may need some expenditure/time.
                                      Norbert
                                      • AnssiA Offline
                                        Anssi
                                        The filesize went to half after purging. Still it is enormous. And as expected, it's the 3D plants that make it slow. Erase them (or replace with something simple), and it flies.
                                        I did not try drawing in it. Before I did anything with it, zooming to extents took 7 seconds, and "purging all" took 40 seconds on my humble non-HT 2.8 GHz P4 laptop.
                                        Anssi
                                        Anssi
                                          toxicvoxel
                                          While this file is obviously fairly heavy I do not have a problem working in it.(But then maybe it's because I wasted the money on the graphics card...)
                                          But you won't believe me unless you see it for yourself.Quadro FX4600
                                          BEAR IN MIND I WAS RECORDING THE AVI IN THE BACKGROUND WHILE THIS WAS GOING ON.
                                          • Now try doing that on your single core Pentium with a gaming card!
                                            toxicvoxel
                                            I believe that the Sketchup-multicore-performance-loss reports are an urban myth not based on actual experience.
                                            Yes SU does not support multi-threading. But most often Sketchup will be used in conjunction with multiple other applications open at the same time and here multi-core machines show a significant advantage over single core machines where the second/third/fourth cores can be used by the other applications while SU does not have to share a single (albeit slightly faster) processor with other applications and even the activities of the OS. The newer Dual/Quad (SANTA ROSA or newer) cores also integrate dynamic accelleration technology that overclocks the first core for single threaded applications:
                                            WIKIPEDIA
                                            The [Centrino] Santa Rosa platform comes with dynamic acceleration technology. It allows single threaded applications to execute faster. When a single threaded application is running the CPU can turn off one of the CPU cores and overclock the active core. In this way the CPU maintains the same Thermal Profile as it would when both cores are active. Santa Rosa performs well as a mobile gaming platform due to its ability to switch between single threaded and multithreaded tasks.[2]. Other power savings come from an Enhanced Sleep state where both the CPU cores and the chipset will power down.
                                            Centrino - Wikipedia
                                            (en.wikipedia.org)
                                            I use a dual core laptop (HP compaq 8710W 2.2GH proc. with 2G ram) that blows the socks off my old Pentium 3.4 machine with the same RAM. More recently I bought a 2.4 GH Quad core machine that is a lot faster than the laptop using Sketchup and SO quick switching between AutCAD, Excel, Painter and CorelDRAW etc. - all of which I now leave open most of the time while working with SU.
                                            Therefor I believe that the real bottleneck is the graphics card. Previously I used an NVIDEA Geforce 6600. The laptop has a Quadro FX1600 and the QuadCore a Quadro FX4600.
                                            BUY the best one you can afford and dont believe those knocking multiple cores.
