    Quad core: slow
    35 Posts 10 Posters 6.9k Views 10 Watching
    • T
      toxicvoxel
      Jeff,
      That is off course what you would expect. But with my Quadcore setup I can run two/three sessions of Sketchup (great for paste-in-place or working on large external referenced component elements with the master model open sepparately) at the same time each on a sepparate core without a bottleneck where everything is calling one processor at the same time, as on my old (faster) Pentium 3.4GH. Also this allows me to save out large images out in one session while still working in another SU session window - something I definitely cannot do on the SC Pentium 3.4GH.
      All things considered the Quad setup is (for me) a lot quicker (with a good graphics card) than a single core setup The single-core recommendation ONLY makes sense if you run one sketchup session without any other applications open.
      • jeff hammondJ
        if you have 3 separate sketchup files open, they are still only using one of your cores so that justification goes out the window.. plus for the most part, if you're working on separate drawings at once, the background files sit idle (talking cpu here - the background files will still use up some ram..)
        i really can't see any advantage in using a slower per chip multicore machine vs a faster single core when running sketchup.. if you're rendering with another app in the background for instance then yes, there's an obvious advantage but if sketchup is open, it's only using one core - regardless of how many drawing you have going at once..
        bottomline is that sketchup needs multicore support...
          remus
          Jeff, you can set process' to run on different cores, so if you had a qud core machine and three different SU window open, you could set one instance of SU to run on one core, and then another on a different core, etc.
          EDIT: this is in vista btw, not sure what the case is with os x.
          • T
            toxicvoxel
            How many of those offering advice here actually uses a quadcore with a descent graphics card set up to optimise running SU? If not your theoretical input could be misleading to those looking for real information on which to base purchases or system setup.
            • jeff hammondJ
              not sure what you're going to say is a decent card is but i use a geforce 8800gt with an intel mac 2.66 quad.. 5g ram...
              truth is, i don't notice much of a sketchup performance boost with my desktop over my laptop (g4 powerbook... 1.33 PPC chip.. 1.5g ram..)... it's just that on the laptop, i pretty much have to close all apps except sketchup to get it to run good so in the case of multitasking, multi cores are a no brainer.. (in contrast, i do a lot of image toning/management/editing with ~80mb files and there are incredibly noticeable performance differences between the two machines while using apps such as photoshop...)
              .. most sketchup operations aren't very demanding and i only notice major enhancements with the faster chip for certain things -- complex follow me deals, soap skin bubble, joint push pull, copy/move etc.. those are the instances where i wish for multicore support because i do a lot of complex curve type of drawings which i think i could simply coast through if i weren't relying on one core..
              strictly speaking sketchup however, a quad is going to offer little to no performance enhancement.. to say otherwise is misleading.. my quad can deal with higher entity drawings better than the laptop but that's due to the better card.. still, that difference isn't highly noticeable and once i get to around 25,000 pieces, the quad will start to glitch.. the problem is in the programing and you can't just throw money at it to deal with it.. instead of doing the my machine is bigger than yours argument and discussing minimal gains after a couple thousands of dollars worth of upgrades - it would make more sense to get the programming right first...
              • T
                toxicvoxel
                Jeff, your argument obviously does not support multi-threading...
                Did anyone say that SU would be faster on Quad - all other things being equal?
                What I did suggest is that the performance loss is propbably due to an inferior graphics card rather than the MC processor. This is supported by the response by Pazu to the question on the Google forums.
                http://groups.google.com/group/Sketchup-Pro/browse_frm/thread/e1a7e5c20e16c98e/6c661597f33b7c47#6c661597f33b7c47
                I suggest to you that waiting for HQ to rewrite the SU code rather than spending money on a good graphics card may not be realistic advice to the initial inquiry.
                • jeff hammondJ
                  seriously, how much of the problem is going to be solved by buying a thousand dollar video card?... i'm assuming the OP is working on fairly large drawings (garden design - plants/leaves/etc) without too much organization.. the best (and cheapest) solution would be to start using groups and components which can be hidden or replaced with low poly versions while doing the bulk of the project..
                  • AnssiA
                    Anssi
                    The few "official" responses from the SU team to queries like this have always stressed that SU performance is more dependent on the CPU than on the graphics card, and that a "decent"(whatever is meant with it) card is enough. They also have said that the workload is divided between the CPU and GPU so that the CPU takes care of the geometry while textures and shadows are generated by the GPU.
                    My models are small, and I generally don't use tons of textures. My oldest computer is a 2.66 GHz P4 with a 64 Mb old ATI All-in-wonder card, and it runs SU 6 quite OK. At work I have a 3.6 GHz P4 with a Quadro FX 1400 card. Looking at the specs, it should run circles around the other, but in practice it is, well, just noticeably faster, as an user experience, the performance boost is even smaller than the difference in CPU clock speed.
                    Of course my next computer will be a multicore, but I just don't see a pressing need to upgrade just yet.
                    Anssi
                    • T
                      toxicvoxel
                      Well the guy has already 'upgraded' to quadcore and is looking for a way to achieve performance comparable to his older machine - to which I have made my recommendation for a better graphics card based on my actual experience - which has been confirmed by a specialist on the Google forum that the specific card he uses is creating the bottleneck.
                      If the bloke has to go on the advice given by some here he should do one or a combination of the following:
                      1.Don't upgrade to multicore for the time being(Too late!)
                      2.Find a largely redundant & outdated single core Pentium 3GH+ instead and work with a single window session at a time. (!)
                      3. Wait for sketchup to support multithreading before spending any more money on a graphics card.(Yeah right!)
                      4. Work with smaller and better organised models than before.(Not always possible.)
                      In context with his question is this the most helpful response that this forum can offer?
                      • jeff hammondJ
                        and..
                        5.. go spend a $1000+ on a graphics card so you'll be able to rotate your model more cleanly while shadows are turned on..
                        the only real solution here is to work in a more organized fashion... everything else in the thread simply states that what he is experiencing is normal and should be expected.. (well, at least what i think he's experiencing... he hasn't replied or gone into detail about what exactly he's experiencing)
                        • T
                          toxicvoxel
                          I guess that answers my question.
                          • AnssiA
                            Anssi
                            There has often been talk about the need for a SU benchmark. That would probably stop us from arguing.
                            About the video card issue: If it is reasonably current, and SU can be made to run with Hardware Acceleration on, I am rather convinced that changing it is not money well spent.
                            I have seen posts in these forums where people who have upgraded from a mediocre Geforce card to an ultracool whizbang QuadroFX complain about zero performance gain. (Yes, agreed, when speccing for a new machine for pro SU use you should go QuadroFX if you can afford it)
                            Anssi
                            • T
                              toxicvoxel
                              Well Anssi, I actually use this combination of hardware, so I'm not speculating on this or giving second hand advice. I can only reiterate that in my experience a top-end card in conjunction with MC has speeded up my workflow significantly. - But then maybe this is my imagination...
                              PS: If you do a search you will find that I actually suggested that a benchmark be developed as a SCF community project, but it was pooh-poohed by the other ruby programmers. Maybe I will just have to write one myself if it means that we can eliminate speculative advice about machine performance.
                                s_arrow
                                First of all, thank very much for all of the answers and advices. I have two videos and a "sku" file uploaded if anyone can see if the composition is too complex:
                                Videos are:
                                http://www.youtube.com/watch?v=cYFyHbNtHls
                                http://www.youtube.com/watch?v=6bsdNHqQ06Y
                                (sorry for the quality, but you can see clearly that the lines takes too long to show up after mouse clicking).
                                The "sku" file is uploaded at:
                                http://rapidshare.com/files/99299925/sketchuptest.rar
                                I'm really happy for all of your help.
                                Greets.
                                • jeff hammondJ
                                  wow.. that is the biggest skp i've ever opened and it definitely slows my system to a crawl.. there's well over a million edges and faces + tons of materials, images, etc.. sketchup simply isn't designed for this type of abuse..
                                  --model info for those that haven't downloaded the file...
                                  15.5 MB
                                  Edges 857746
                                  Faces 318839
                                  Component Instances 137582
                                  Guide Points 30
                                  Groups 2659
                                  Images 12
                                  Component Definitions 108
                                  Layers 121
                                  Materials 171
                                  Styles 1
                                  looking forward to hearing how toxic's system deals with this thing..
                                    remus
                                    Thats a pretty weighty test file, surprisingly my system just about handled it, there was a second or two delay when orbiting, and i didnt dare to turn on shadows or xray, but you could work with the model if you needed to.
                                    • jeff hammondJ
                                      yeah, i guess if you have tons of patience it would be workable but seriously, i couldn't handle it.. i can rotate it ok, draw lines decently, etc.. the problem starts showing itself once you try drawing some stuff..
                                      ex - it takes me 6 seconds to draw a sphere in a blank window.. with this drawing, it took me 27 seconds.. going off of that, it would take a full days work to draw something that would take 2hrs.. i'll pass.. (and i didn't have to rotate the model in order to draw the sphere - doing that would take even longer)
                                      i would seriously look into some renderers to deal with all these plants instead of trying to draw them all in sketchup.. plus, the final output will look way better anyway..
                                        remus
                                        Yeah, im sure it would be a far better idea to use something like those proxies kwist was experimenting with. Or even just add the components in the renderer.
                                        • sketch3d.deS
                                          sketch3d.de
                                          @anssi said:
                                          ... upgraded from a mediocre Geforce card to an ultracool whizbang QuadroFX complain about zero performance gain.
                                          sure, comparing speed of a GeForce w/ an Quadro FX in the same price range will show a better performance for the GF. The advantage of the Quadros is the quailty of the driver especially if a full and stable OpenGL support is required.
                                          anyway, SU is currently CPU driven sothat the fastest dual core CPU is probably the best choice for a performance optimized system and probably the best bang-for-the-buck compared w/ quad core systems.
                                          iirc for getting the user the impression that a system double its speed the system performance needs to be roughly quadrupled 😲
                                          rewriting SU for a multi-threading of modeling operations is probably a difficult task compared with slicing a render output in mutiple chunks, may need some expenditure/time.
                                          Norbert
                                          • AnssiA
                                            Anssi
                                            The filesize went to half after purging. Still it is enormous. And as expected, it's the 3D plants that make it slow. Erase them (or replace with something simple), and it flies.
                                            I did not try drawing in it. Before I did anything with it, zooming to extents took 7 seconds, and "purging all" took 40 seconds on my humble non-HT 2.8 GHz P4 laptop.
                                            Anssi
                                            Anssi
